Hi, I’m using an AR750 with FW 2.272 and the mobile version of the router’s webpage is not showing the ribbon with App repo / cloud / share / upnp / opvenvpn while the desktop does.
Is there a way to add it , especially for openvpn ?
I’ve not tested FW 3.XXX yet though… same miss ?
Thank you
The old firmware(v2.0) isn’t friend for mobile. You can upgrade to v3.0 firmware, which has optimized for mobile browser.
