I am trying to connect to OpenVPN with all my files in my GL-MT300N-V2:
cert.txt
he-ca.txt
ket.txt
default.ovpn
This is my .ovpn file:
client
dev tun
remote XXXXXXXX
remote XXXXXXXXXXXX
port 1194
pull
auth-user-pass
tun-mtu 1500
mssfix 1400
key key.txt
cert cert.txt
ca he-ca.txt
compress lzo
keepalive 10 60
nobind
float
cipher BF-CBC
remote-cert-tls server
push-peer-info
auth-nocache
I upload the files into a zip but no user/password is prompted but a passphrase that I don’t have. I tried to upload the firmware but the error continues. My current firmware version is 3.203.
“askpass” solution is not working…
I needed to do some new parameter so I tried this solution …
installation is working fine but while launching this vpn, connection is not working.
better use the zip files provided by your VPN service as I said
there are 4 files inside
ca.crt
client.crt
client.key
openvpn.ovpn
“Do you mean a passphrase used to encrypt the cert/keys?”
don t know if this question is for me or not
passphrase is ussually used to encrypt the cert/keys, but in my case no passphrase is provided by my VPN provider.
If there is this line the UI will ask you to provide username and password. Some vpn service provider provide a different username and password for vpn connection which is different from your login username/password in their website.
askpass
If you have this line the UI will ask you to input private key passphase. Pls note, sometimes in the ovpn there is no this line (e.g. pivpn) and you need to add this manually.
