I just bought the GLI GL-MT300A.
Everything’s fine. I upgraded the firmware to 2.264.
My openvpn works perfectly on my iPhone and iPad but when I upload the.openvpn file to the GLI the openvpn I get an “OpenVpn is not started” error with no log and no other problems.
@glitch is right @caryl-gervereau. Set up a test OpenVPN server on your own pc, and try to connect with the router, you will see it will work without issues. One common thing is using the TAP vs TUN openvpn setting.
You should probably have TUN for most configs, and that works great, i use it every day.
Thank you for this information.
the problem is that this.ovpn file works perfectly on MacOS (With Tunnelblick) on iOS (iPhone and iPad)…and I’m well in TUN…
It just doesn’t work on the mini router…it’s weird.
For information the file passwords in the cache. Maybe I need to disable it on the mini router…I’m testing…
