OpenVPN on MT300N-V2
A question concerning Open VPN:
I try to use the OpenVpn server on a MT300N-V2.
I generate the config as it is writing… I pick up the config file for the client.
But no way to start a link OpenVPN (directly on the wan port no routing no firewall)
The data receive and data send stay at 0 on the MT300N-V2 side and the client goes in timeout with no answer after the wait state looks like if the port is locked on the MT300N-V2…
What client are you using? Can you post the content of ovpn file?
Hello, I m using an OpenVpn client from openVpn on a Win 7 Pro.
Sorry for file but new user can’t upload file on the forum… so i just copy behind.
Thank you by advance for your help.
client
dev tun
proto udp
remote 192.168.0.163 1194
resolv-retry infinite
nobind
persist-key
persist-tun
auth SHA1
cipher BF-CBC
comp-lzo adaptive
nice 0
mute 5
verb 3
-----BEGIN CERTIFICATE-----
MIIC/TCCAeWgAwIBAgIJAOKwrJK+akkVMA0GCSqGSIb3DQEBBQUAMBUxEzARBgNV
BAMMCk9wZW5WUE4gQ0EwHhcNMTgwNjE4MTM0NTQxWhcNMjgwNjE1MTM0NTQxWjAV
MRMwEQYDVQQDDApPcGVuVlBOIENBMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIB
CgKCAQEAy4ASjrYBE9Le8Qh2XRIN2GiNtm6a2I8MugxbDPpV4+a/iqTBBG2b5jPz
ha8+c4VBpV083l++acvJrAz/6d4taPr5tB2+d13UvLPeedztXJuj4wxlcUc48FPd
f6CSp4zZjgerk5hPtsSVoBj8NWio/fNFrOWh9Zjk/DIfoot9AE4I9z9Z7FUBoDBi
ICcqGbwKfZfzIvVki+7KvZ51hRsSE8oOMR8s7iE9fr+mRpyoimAB8ASAsIc6IC91
BTt+RXS3G1OII0O22dPjReReJvlej2wUVYjiDH2Pzqc7CE+ju2J0oAJt+eXLC+Wr
XaGm6blswYco3Tbt1Ohx2RBvRobMFwIDAQABo1AwTjAdBgNVHQ4EFgQU1w4xorYr
PL9fJRtcHTjk9JAxoDYwHwYDVR0jBBgwFoAU1w4xorYrPL9fJRtcHTjk9JAxoDYw
DAYDVR0TBAUwAwEB/zANBgkqhkiG9w0BAQUFAAOCAQEArcI0XJXyTyMGhN41zwYp
ZORQ7XZ3gYsjvWRlLrYJlxj7Uco8Yu2j/tQN8Ax0h//JspqiA7kv19HitkNTQqtN
J3/cwSIonSSZg/mjNZ/rF6hd51JuVRov38IM55L3hKzPniK9NYjPGDi+zBCXr0iD
36PycJrzASvhpwnCAH4EHLpwwhf8nU5Vk6eQ24j0WmZEryA/09l2OPbJqCelS1Rh
z4ynbVA01vvJtw/Nop5avN5MRc33RHIcw1oeIIuF5kwmbhP9tL5+gH2eyVbcCt6/
s3ea8bCCHTk2YALAnd7vlgmIwDjiF8g4N52LazdFlpmYkfAgAmXPxxtkTtE57tue
IA==
-----END CERTIFICATE-----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-----BEGIN PRIVATE KEY-----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-----END PRIVATE KEY-----
To follow the client log:
Thank’s:
Thu Jun 21 08:23:57 2018 Socket Buffers: R=[8192->8192] S=[8192->8192]
Thu Jun 21 08:23:57 2018 UDP link local: (not bound)
Thu Jun 21 08:23:57 2018 UDP link remote: [AF_INET]192.168.0.163:1194
Thu Jun 21 08:23:57 2018 MANAGEMENT: >STATE:1529562237,WAIT,
Thu Jun 21 08:24:57 2018 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Jun 21 08:24:57 2018 TLS Error: TLS handshake failed
Thu Jun 21 08:24:57 2018 SIGUSR1[soft,tls-error] received, process restarting
Thu Jun 21 08:24:57 2018 MANAGEMENT: >STATE:1529562297,RECONNECTING,tls-error,
Thu Jun 21 08:24:57 2018 Restart pause, 10 second(s)
Thu Jun 21 08:25:07 2018 WARNING: No server certificate verification method has been enabled. See How To Guide: Set Up & Configure OpenVPN Client/server VPN | OpenVPN for more info.
Thu Jun 21 08:25:07 2018 TCP/UDP: Preserving recently used remote address: [AF_INET]192.168.0.163:1194
Thu Jun 21 08:25:07 2018 Socket Buffers: R=[8192->8192] S=[8192->8192]
Thu Jun 21 08:25:07 2018 UDP link local: (not bound)
Thu Jun 21 08:25:07 2018 UDP link remote: [AF_INET]192.168.0.163:1194
Thu Jun 21 08:25:07 2018 MANAGEMENT: >STATE:1529562307,WAIT,
Thu Jun 21 08:26:07 2018 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Jun 21 08:26:07 2018 TLS Error: TLS handshake failed
Thu Jun 21 08:26:07 2018 SIGUSR1[soft,tls-error] received, process restarting
Thu Jun 21 08:26:07 2018 MANAGEMENT: >STATE:1529562367,RECONNECTING,tls-error,
Thu Jun 21 08:26:07 2018 Restart pause, 20 second(s)
Thu Jun 21 08:26:27 2018 WARNING: No server certificate verification method has been enabled. See How To Guide: Set Up & Configure OpenVPN Client/server VPN | OpenVPN for more info.
Thu Jun 21 08:26:27 2018 TCP/UDP: Preserving recently used remote address: [AF_INET]192.168.0.163:1194
Thu Jun 21 08:26:27 2018 Socket Buffers: R=[8192->8192] S=[8192->8192]
Thu Jun 21 08:26:27 2018 UDP link local: (not bound)
Thu Jun 21 08:26:27 2018 UDP link remote: [AF_INET]192.168.0.163:1194
Thu Jun 21 08:26:27 2018 MANAGEMENT: >STATE:1529562387,WAIT,
Thu Jun 21 08:27:27 2018 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Jun 21 08:27:27 2018 TLS Error: TLS handshake failed
Thu Jun 21 08:27:27 2018 SIGUSR1[soft,tls-error] received, process restarting
Thu Jun 21 08:27:27 2018 MANAGEMENT: >STATE:1529562447,RECONNECTING,tls-error,
Thu Jun 21 08:27:27 2018 Restart pause, 40 second(s)
Where is your windows client located? In the same network as the mini router server?
I assume you want to use the server outside your home/office. here is what you should do
Change the IP to your public IP. You can check this in your main router.
Set up port forwarder in your main router, from 1194 to 192.168.0.163 1194
No i just try in house : mean Wan port of the M300 is on 192.168.0.0 with 255.255.255.0
My client is 192.168.0.12 that try to open vpn target to 192.168.0.163 1194
So no third part routing or wath ever…
With this i thing i m in the basic to try the open vpn?
Am I wrong?
@didier Which openvpn software on win 7 do you use?
OpenVPN Service ver.: 2.4.6.0
