Hi All,
I just started using the MT300a with OpenVPN. Very satisfied so far.
However, I am not comfortable with the fact that my privacy depends on the robustness of a single tunnel or a single VPN server.
I would like to create a script that manages multiple concurrent OpenVPN tunnels to a pool of random servers and rotates them regularly. This is the logical flow of what I am trying to achieve:
Block1 - repeat 6 times
select random config file unless it is flagged (see further steps)
start tunnel
verify tunnel is up. If not flag the file and start at the beginning of the block
start a random timer between 30 and 90 minutes
add static route, NAT and forwarding policies
Block2-regularly check each tunnel is up
if not, flag file and execute block 1 once
Block3-when timer expires
prevent new sessions towards the tunnel
wait for active streams to expire or complete (maybe reduce TCP timeouts beforehand)
delete static route, NAT and forwarding policies
delete tunnel
So, in theory, this should keep 6 concurrent connections active, each lasting on average an hour, and distribute connections randomly among them.
Have any of you attempted anything similar or are you aware of any possible limitation?
Thanks!
