GL.iNet GL-AR300M16 (GL-AR300M Series / Shadow) router with an OpenVPN server setup and running
The ISP router is set-up as a bridge. With a router mode, the IP is private, and when connected to it directly or through the Shadow router (without OpenVPN), I can see it’s private:
However with a bridge mode it changes to public:
The Shadow router is connected as a repeater:
https://i.imgur___DOT___com/64wTfFT.png
When I configure and export OpenVPN file I get:
https://i.imgur___DOT___com/2TIc0Cb.png
The IP in line 4 is what I see when googling my IP address.
I can start the server but I can’t connect it. I’ve tried different ways:
from Android phone and Windows laptop
from the same WiFi (connecting to the Shadow router) and through another internet provider
What do you mean by “googling my IP address”? When I export an OpenVPN .opvn config, it contains the remote IP address of my real public IP and matches what is shown by whatismyip.com and whatismyipaddress.com.
You can look up the 89.x.x.x IP address on those 2 websites to see who owns it and where it is. Was your router connected as a client to an external VPN when you exported the config?
You can try editing the config file and changing the remote address to your 100.x.x.x Public IP address.
Yes, unfortunately that’s correct - I’m speaking with the ISP to get a public IP.
Assuming that’s done, would the Shadow router allow me to set up VPN server that I’d be able to connect to from outside my home and would allow me to access my home internet? Or, when connecting from outside, I’d only access the internal/home network?
If you have a public IP for your home, you can set up Wireguard server, connect to it then: (1) You can use Internet from your home; (2) You can connect to your home local network.
