I am trying to create a client/server pair with 2 AR300M’s.
It’s not working.
Both of my routers are on the LAN side of my home router to test concept. I am largely sing the OpenWRT Basic config, below.
Thoughts?
It’s not working.
Thoughts?
I’d like to try but don’t have a time these days.
How did you generate the keys?
Can you try to check if the server is working using other openvpn client, e.g. in windows or Linux?
What does it say in the UI when you using openvpn client? You can also check using “logread”.
Thank you for your time, and your service. I’m sure you are busy.
I created my keys using easy-rsa.
I will try a windows client.
I will post the log later…
