I have a sofware problem.When I use softenter vpn , it can auto generate a ovpn for openvpn.This ovpn file success used in window client , but when use in route ar150 it will lead a problem , this is the screenshot!
2021-05-21T16:00:00ZIs there any way that you can test your ovpn in Linux? or Windows WSL (Windows subsystem for Linux).
Can you send me a ovpn privately to check?
Actually , I only have a windows 2012r2 services. May I know your e-mail address?
Send me a direct message via the forum is ok.
Click the name and you can find message choice.
Otherwise you can just send to support at gl-inet.com
I have send the ovpn file to support@gl-inet.com. Thank you!
Replied you via email. Seems it is caused by ipv6
