I have upgrade my AR300M with 2.26 firmware (after resetting my settings) and I have now a problem with OpenVPN. I can connect to my VPN server and after a minute the connection is dropped. I cannot connect anymore after because the session is still opened on the server and I cannot open a new session. I was not having this problem with 2.25 firmware.
Here are some logs, can you help me ?
Wed Jun 28 09:30:38 2017 daemon.notice openvpn[7230]: OpenVPN 2.4.0 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] Wed Jun 28 09:30:38 2017 daemon.notice openvpn[7230]: library versions: OpenSSL 1.0.2g 1 Mar 2016, LZO 2.08 Wed Jun 28 09:30:39 2017 daemon.notice openvpn[7233]: TCP/UDP: Preserving recently used remote address: [AF_INET]XXX.XXX.XXX.XXX:23545 Wed Jun 28 09:30:39 2017 daemon.notice openvpn[7233]: UDP link local: (not bound) Wed Jun 28 09:30:39 2017 daemon.notice openvpn[7233]: UDP link remote: [AF_INET]XXX.XXX.XXX.XXX:23545 Wed Jun 28 09:30:39 2017 daemon.warn openvpn[7233]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this Wed Jun 28 09:30:41 2017 daemon.notice openvpn[7233]: [Freebox OpenVPN server XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX] Peer Connection Initiated with [AF_INET]XXX.XXX.XXX.XXX:23545 Wed Jun 28 09:30:42 2017 daemon.notice netifd: Interface 'VPN_client' is enabled Wed Jun 28 09:30:42 2017 daemon.notice netifd: Network device 'tun0' link is up Wed Jun 28 09:30:42 2017 daemon.notice netifd: Interface 'VPN_client' has link connectivity Wed Jun 28 09:30:42 2017 daemon.notice netifd: Interface 'VPN_client' is setting up now Wed Jun 28 09:30:42 2017 daemon.notice openvpn[7233]: TUN/TAP device tun0 opened Wed Jun 28 09:30:42 2017 daemon.notice openvpn[7233]: do_ifconfig, tt->did_ifconfig_ipv6_setup=0 Wed Jun 28 09:30:42 2017 daemon.notice openvpn[7233]: /usr/sbin/ip link set dev tun0 up mtu 1500 Wed Jun 28 09:30:42 2017 daemon.notice openvpn[7233]: /usr/sbin/ip addr add dev tun0 local 192.168.27.65 peer XXX.XXX.XXX.XXX Wed Jun 28 09:30:42 2017 daemon.notice netifd: Interface 'VPN_client' is now up Wed Jun 28 09:30:42 2017 daemon.notice openvpn[7233]: Initialization Sequence Completed Wed Jun 28 09:30:43 2017 user.notice firewall: Reloading firewall due to ifup of VPN_client (tun0) Wed Jun 28 09:31:44 2017 user.notice mwan3track: Interface tethering (eth2) is offline Wed Jun 28 09:31:44 2017 user.notice mwan3: ifdown interface tethering (eth2) Wed Jun 28 09:31:45 2017 daemon.err openvpn[7233]: event_wait : Interrupted system call (code=4) Wed Jun 28 09:31:45 2017 daemon.notice openvpn[7233]: /usr/sbin/ip addr del dev tun0 local 192.168.27.65 peer XXX.XXX.XXX.XXX Wed Jun 28 09:31:45 2017 daemon.notice netifd: Network device 'tun0' link is down Wed Jun 28 09:31:45 2017 daemon.notice netifd: Interface 'VPN_client' has link connectivity loss Wed Jun 28 09:31:45 2017 daemon.notice netifd: Interface 'VPN_client' is now down Wed Jun 28 09:31:45 2017 daemon.notice openvpn[7233]: SIGHUP[hard,] received, process restarting Wed Jun 28 09:31:45 2017 daemon.warn openvpn[7233]: Note: option tun-ipv6 is ignored because modern operating systems do not need special IPv6 tun handling anymore. Wed Jun 28 09:31:45 2017 daemon.notice openvpn[7233]: OpenVPN 2.4.0 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] Wed Jun 28 09:31:45 2017 daemon.notice openvpn[7233]: library versions: OpenSSL 1.0.2g 1 Mar 2016, LZO 2.08 Wed Jun 28 09:31:45 2017 daemon.notice netifd: Interface 'VPN_client' is disabled Wed Jun 28 09:31:50 2017 daemon.notice openvpn[7233]: TCP/UDP: Preserving recently used remote address: [AF_INET]XXX.XXX.XXX.XXX:23545 Wed Jun 28 09:31:50 2017 daemon.notice openvpn[7233]: UDP link local: (not bound) Wed Jun 28 09:31:50 2017 daemon.notice openvpn[7233]: UDP link remote: [AF_INET]XXX.XXX.XXX.XXX:23545 Wed Jun 28 09:31:50 2017 user.info mwan3track: Lost 20 ping(s) on interface tethering (eth2) Wed Jun 28 09:31:51 2017 daemon.notice openvpn[7233]: [Freebox OpenVPN server XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX] Peer Connection Initiated with [AF_INET]XXX.XXX.XXX.XXX:23545 Wed Jun 28 09:31:52 2017 daemon.notice openvpn[7233]: AUTH: Received control message: AUTH_FAILED Wed Jun 28 09:31:52 2017 daemon.notice openvpn[7233]: SIGUSR1[soft,auth-failure] received, process restarting
