I’m having issues logging into a VPN where the client is using a static-challenge for the Google Authenticator code. The popup for the code does not appear in the web interface and the connection attempt hangs.
Is there a way to get this to work on the GL-AR750S?
I have attempted to kill and start the openvpn connection using the command provided, but it doesn’t work.
I typed in: openvpn -f /etc/openvpn/client.ovpn
I received this message from the terminal:
Options error: I’m trying to parse “-f” as an --option parameter but I don’t see a leading ‘–’
Use --help for more information.
Both of those commands show this response:
-ash: {processId}:not found
Please provide the full command that I need to run. What do I need to include regarding the process? Are there additional commands that must be run first?
Note: {processId} stands for the random numerical value assigned to the process, which is what I input in my command.
Neither of these were successful in restarting the service. Again, if you are willing to respond, I’m grateful, but please include the entire command necessary in your response.
