Hi!
Bought a GL-MT3000 as a travel companion to easily connect my IOT devices etc. when I am not at home.
I do need a TAP bridge, as I need the layer 2 traffic. My router at home is running Pfsense.
My ultimate goal is to have the GL router connect to the Pfsense for my Pfsense to seamlessly hand out IP-addresses to my connected devices through the GL via the Pfsense DHCP. I would like like to bind the ETH1 (LAN) interface and a new WiFi with SSID called IOT to the VPN TAP bridge.
I quickly discovered that Luci is my friend here, even though I know next to nothing about OpenWRT.
I already have the TAP S2S VPN (Pfsense as server, GL as client) established between pfsense and GL router, it is up and running, and if I configure a unmanaged tap0 interface and bridges that on the br-lan on the GL, I can get an IP-address on my IOT network handed out by the Pfsense and ping between devices without a problem.
But as stated, I would like to create a new network on the GL, instead of using the default LAN-network and br-lan. But I can't seem to wrap my head around that part.
How would I create a new network, and bridge that to the tap0 interface, to work both on ETH1 and one single WLAN ? - and how would I create that WLAN. I am aware that I won't get any IP-adresses assigned, before the S2S VPN is up, that's alright.
I have a feeling that it's rather simple when you know how ![]()
The firewall rules might be all over the place, don't really know about those.
I can post my OpenVPN client config, if it could be useful for anyone.
Here's my configs, this is the state that is currently working, when the tap0 interface is added on br-lan.
/etc/config/network
root@GL-MT3000:~# cat /etc/config/network
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fdef:0a60:a21b::/48'
config device
option name 'br-lan'
option type 'bridge'
option macaddr '94:83:c4:46:90:3e'
list ports 'eth1'
list ports 'tap0'
config device
option name 'eth1'
config interface 'lan'
option device 'br-lan'
option ipaddr '192.168.8.1'
option ip6assign '60'
option isolate '0'
config device
option name 'eth0'
option macaddr '94:83:c4:46:90:3d'
config interface 'wan'
option device 'eth0'
option proto 'dhcp'
option force_link '0'
option ipv6 '0'
option metric '10'
config interface 'wan6'
option proto 'dhcpv6'
option disabled '1'
option device '@wan'
config interface 'tethering6'
option disabled '1'
option device '@tethering'
config interface 'wwan6'
option disabled '1'
option device '@wwan'
config interface 'guest'
option force_link '1'
option ipaddr '192.168.9.1'
option multicast_querier '1'
option igmp_snooping '0'
option isolate '0'
option bridge_empty '1'
option disabled '1'
config interface 'wwan'
option proto 'dhcp'
config interface 'modem_1_1_2_6'
option disabled '1'
option device '@modem_1_1_2'
config rule 'policy_direct_rt'
option lookup 'main'
option suppress_prefixlength '0'
option priority '1100'
config rule 'policy_default_rt_vpn'
option mark '0x8000/0xc000'
option lookup '8000'
option priority '1101'
option invert '1'
config rule6 'policy_direct_rt6'
config rule6 'policy_default_rt_vpn6'
option invert '1'
config rule 'policy_default_rt_vpn_ts'
option priority '1099'
option mark '0x80000/0xc0000'
option invert '0'
config interface 'IOT_S2S_VPN'
option device 'tap0'
option proto 'none'
/etc/config/firewall
root@GL-MT3000:~# cat /etc/config/firewall
config defaults
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
option synflood_protect '1'
config zone
option name 'lan'
option forward 'ACCEPT'
list network 'lan'
config zone
option name 'wan'
option mtu_fix '1'
option input 'DROP'
option masq '1'
list network 'wan'
list network 'wan6'
list network 'wwan'
config forwarding
option src 'lan'
option dest 'wan'
option enabled '1'
config rule
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
option src_ip 'fe80::/10'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'bad-header'
option limit '1000/sec'
config rule
option src 'wan'
option dest '*'
option proto 'icmp'
config rule
option name 'Allow-IPSec-ESP'
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option name 'Allow-ISAKMP'
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config rule
option name 'Support-UDP-Traceroute'
option src 'wan'
option dest_port '33434:33689'
option proto 'udp'
option target 'REJECT'
option enabled 'false'
config include
config include 'nat6'
option path '/etc/firewall.nat6'
option reload '1'
config rule 'block_dns'
option name 'block_dns'
option src '*'
option device 'br-+'
option dest_port '53'
option enabled '0'
config rule 'process_mark'
option name 'process_mark'
option dest '*'
option proto 'all'
option extra '-m owner --gid-owner 65533'
option target 'MARK'
option set_xmark '0x8000/0xc000'
config rule 'wan_in_conn_mark'
option name 'wan_in_conn_mark'
option src 'wan'
option dest '*'
option extra '-j CONNMARK --set-xmark 0x8000/0xc000'
option enabled '0'
config rule 'lan_in_conn_mark_restore'
option name 'lan_in_conn_mark_restore'
option src 'lan'
option dest '*'
option extra '-m connmark --mark 0x8000/0xc000 -j CONNMARK --restore-mark'
option enabled '0'
config rule 'out_conn_mark_restore'
option name 'out_conn_mark_restore'
option dest '*'
option enabled '0'
config include 'swap_wan_in_conn_mark'
option type 'script'
option reload '1'
option path '/etc/firewall.swap_wan_in_conn_mark.sh'
option enabled '0'
config include 'gls2s'
option path '/var/etc/gls2s.include'
option reload '1'
config include 'glblock'
option path '/usr/bin/gl_block.sh'
option reload '1'
config zone
option name 'guest'
option input 'REJECT'
list network 'guest'
config forwarding
option src 'guest'
option dest 'wan'
option enabled '1'
config rule
option name 'Allow-DHCP'
option src 'guest'
option proto 'udp'
option dest_port '67-68'
config rule
option name 'Allow-DNS'
option src 'guest'
option proto 'tcp udp'
config include 'vpn_server_policy'
option path '/etc/firewall.vpn_server_policy.sh'
option reload '1'
option enabled '1'
config zone
option name 'S2S_VPN'
option masq '1'
list network 'IOT_S2S_VPN'
config forwarding
option dest 'wan'
option src 'S2S_VPN'
config zone
list network 'lan'
config forwarding
option dest 'S2S_VPN'
config forwarding
config forwarding
option src 'lan'
root@GL-MT3000:~#
