I need your help please regarding this issue.
I have a router GL inet MT300N v2 with firmware 3.0.25.
I have very very slow speeds when I connect to an NordVPN account using OpenVPN client.
I did following tests:
1- connect my PC to MT300N by RJ45, speedtest results = 47 MB/s
2- connect my PC to MT300N by RJ45, connect to Nordvpn server using OpenVPN client, speedtest results = 8 MB/s !!!
3- connect my PC to my home router, run NordVPN windows appli, connect to same Nordvpn server, speedtest results = 41 MB/s
This leads me to think that there is an issue with my MTN300N v2 config
Could anyone please advise how to solve this performance issue ?
Thanks a lot for your answer dear @leone88
Anyone else could please confirm or advise if there is a workaround ?
Going down from 45 MB to 8 MB seems abnormal to me !
OpenVPN on a MIPS-based, router SoC from any vendor is going to be limited to the 10-20 Mbps (aggregate) range without SQM, around 10 Mbps or below with SQM. This is a hardware limitation, not a Gl.iNet limitation.
GL.iNet seems very up-front about the possible performance. See, for example, the GL-AR750S, which runs a faster processor (QCA9563 at 775 MHz vs. MTK7628 at 580 MHz), where they suggest 17 Mbps performance with OpenVPN.
Workarounds:
Use WireGuard – On MIPS-based devices it is roughly 3x faster
Buy a faster (ARM-based) router (would get you into the 20-30 Mbps range)
Use a dedicated SBC or VM to run OpenVPN and pass the traffic through it
Use a dedicated SBC or VM as your router and use the GL-MT300Nv2 as an access point only
Many thanks dear Jeff for your fruitful help.
Would you please help me with the steps to configure WireGuard ?
I could not find a document explaining in detail how to configure it on GL router for NordVPN …
Also, if there is another VPN that supports it, I would love to try it
SQM (bandwidth shaping) is not enabled by default. It is a package that some people choose to add and configure that can reduce latency (“lag”) when either the line or the SoC is close to its limits.
Thanks so much dear Jeff for your outstanding help
One last Q please, you mentioned that without SQM I should have 10-20 MB and I am having only 8 MB by default. Any idea why please ? How could I improve to 15 or 20 please ?
My words were not precise. Their intent was to say that for a MIPS-based SoC, you’re not going to reliably get more than somewhere in the 10-20 Mbps range. There are 400 MHz and even slower MIPS-based SoCs that will probably never get close to 10 Mbps with OpenVPN.
Basically, the rates you’re getting are probably all you can get out of the chip in the device for OpenVPN.
Since the router needs to do more than just run the VPN (receiving packets, deciding where to send them, NAT, sending packets), a 25% slower CPU means more than a 25% slower VPN. I have never tested a device in that speed range for OpenVPN performance, only faster ones.
You can save a little bit when you need the speed by doing things like:
Don’t log into the web interface
Don’t run anything you don’t need to on your router (file sharing, torrents, … )
