I want to check a physical ethernet port status on GL-Inet AR300M flashed with 21.02.1 and all the methods I’ve tried report that eth0 always has carrier even when nothing is plugged in:
@alzhao thanks for your prompt reply. By default there’s no switch configured on OpenWrt 21.02.1:
root@ar300m:~# cat /etc/config/network
config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config device
option name 'br-lan'
option type 'bridge'
list ports 'eth0'
list ports 'eth1'
config interface 'lan'
option device 'br-lan'
option ipaddr '192.168.226.1'
option ipv6 '0'
Here’s the command you requested with cable plugged into LAN port:
root@ar300m:~# swconfig dev switch0 show
Global attributes:
enable_vlan: 0
ar8xxx_mib_poll_interval: 500
ar8xxx_mib_type: 0
enable_mirror_rx: 0
enable_mirror_tx: 0
mirror_monitor_port: 0
mirror_source_port: 0
arl_table: address resolution table
Port 0: MAC 94:83:c4:0e:d7:d1
Port 1: MAC 00:25:00:ed:20:6b
Port 0:
mib: MIB counters
RxGoodByte : 343980 (335.9 KiB)
TxByte : 454574 (443.9 KiB)
pvid: 0
link: port:0 link:up speed:1000baseT full-duplex txflow rxflow
Port 1:
mib: MIB counters
RxGoodByte : 454540 (443.8 KiB)
TxByte : 344166 (336.0 KiB)
pvid: 0
link: port:1 link:up speed:100baseT full-duplex auto
Port 2:
mib: No MIB data
pvid: 0
link: port:2 link:down
Port 3:
mib: No MIB data
pvid: 0
link: port:3 link:down
Port 4:
mib: No MIB data
pvid: 0
link: port:4 link:down
Here’s the command you requested with cable plugged into WAN port:
Global attributes:
enable_vlan: 0
ar8xxx_mib_type: 0
enable_mirror_rx: 0
enable_mirror_tx: 0
Port 0: MAC 00:25:00:ed:20:6b
Port 0:
mib: MIB counters
RxGoodByte : 350022 (341.8 KiB)
TxByte : 456936 (446.2 KiB)
pvid: 0
Port 1:
mib: MIB counters
RxGoodByte : 456552 (445.8 KiB)
TxByte : 347224 (339.0 KiB)
pvid: 0
link: port:1 link:down
Port 2:
mib: No MIB data
pvid: 0
Port 3:
mib: No MIB data
pvid: 0
Port 4:
mib: No MIB data
pvid: 0
As you can see when cable is plugged into WAN, I get the following output from swconfig:
Is the switch configuration section missing from the network config on this device in OpenWrt 21.02.1? How is switch configured with your own firmware?
