Openwrt 24.10 for Creta AR750
I know Creta is EOL this month and I’m not expecting any update really.
But I’m wondering is it possible for me to do a custom build of openwrt 24.10 bundled with all the glinet packages for 4.3.18?
If so can someone give me pointers?
My Creta is still going well but would love 24.10 because it’s fully supported in vanilla.
Thanks
Truly sorry.
We cannot build the op24-GL firmware for AR750.
thanks for reply @bruce
As per below will Creta AR750 soon get same new firmware as AR750s? As they both run same 4.3.18 now.
Different models, the firmware installed is different.
AR750 Flash space is insufficient, it does not have the conditions to update to v4.7, but will update 4.5.x later.
Great. Thanks for the info!
Hi @bruce,
The nor flash and ram for slate and creta are the same.
Given slate now has 4.7.2 beta, will creta receive same treatment?
Thanks again :pray:
Sorry, the AR750S can be upgraded to v4.7.2 because it has NAND Flash 128MB, and the AR750's Flash only 16MB space is not enough to upgrade.
