I installed the openWRT on my GL-X750, but I have no idea how to setup the 4G connection, I tried restoring the backup file, but it was saying that /etc/config/luci was corrupted, is there a way to restore the settings from the original firware to the openWRT?
If i go into luci>network>interfaces with the original firmware I can see the folowing protocol: Protocol: UMTS/GPRS/EV-DO.
But with openWRT this option of protocol is not available.
First
you need to have the necessary kernel modules installed. You can keep a list of the packages of the stock firmware. Use the following command
opkg list-installed
Then search kmod-usb and find the kernel modules. Also you need to have the dial script modules and qmi modules etc.
Record the content of /etc/config/network
Of course you have this if you have backup.
Then
in your vinella firmware you need to check if your modem is loaded. Check /dev/
and find the following devices /dev/ttyUSB0
to ttyUSB4
and /dev/cdc-wdm0
. If yes then it is good to go. Pls config /etc/config/network as the stock firmwar and it should work.
Having the gl-inet firmware fully open source would make it simpler and easier to use, than having to change the firmware and perform those actions. And even attrack more costumers…
