I would like to know which openwrt firmware support GL-USB150? Can I download it from the openwrt website?
Please upgrade to the latest firmware, which is based on OpenWRT-18.06.
I found that it would halted after login to the console page most of the time. I have reset it, upgrade it to 3.01 and downgrade it to 3.00, but issue still exist.
Regards,
Nico
console page? Do you mean the uart or admin web?
the admin page. some times I can’t connect the router, but I can see it on the list.
It will create a network adapter when inserting GL-USB150, could you check if the adapter gains an IP address or not?
