I get today GL-X750V2C6 4G LTE Wireless Gateway, i will my opera VPN Pro as VPN-Client install it.
Please show me the way help me. I am 69 old and good for understandeing.
regards
regards
Running the VPN Client on the GL router using the configuration file provided by your provider is a two-step process:
For step 2, you can refer to WireGuard Client - GL.iNet Docs and How to Set Up WireGuard® Client on GL.iNet Routers - YouTube.
But Opera VPN Pro seems not to offer a solution for downloading VPN configuration files … You will need to try if you can export the configuration file from its client. You could also try a different provider that offers a download configuration file service.
VPN on Router - GL.iNet (gl-inet.com)
