Hi there, we’re making the next generation of Brume. Brume (GL-MV1000) is an edge gateway designed for wired high speed internet connection. For the next generation, we have some rough ideas, and we need your help to finalize. Please cast your vote for the THREE most important features you need:
Compact size
USB 3.0
Gigabit Ethernet port
2.5G Multi-Gig Ethernet port
Type-C power input
Metal case
Plastic case
LED for VPN
LED for customization
Mode switch button
TF card slot
0voters
If your desired options are not included above, please leave comment below.
Besides not having wifi, can you explain the differences between the GL-MV1000 as an “Edge Computing Gateway” and other GL.iNet routers? I have the GL-MV1000W model with 2.4GHz wifi and I can plug in a 5GHz USB wifi adapter, so it becomes just like the other routers.
I think all the features in your survey can apply to all future GL.iNet routers. If you turn off wifi on the new GL-AXT1800, it could be an improved GL-MV1000 and be able to perform all the core functions.
Although more expensive and larger, I currently use an Asus RT-AX88U as my main “edge” router, with the 802.11ax wifi turned off, and it has some features that you can also consider:
At least 5 LAN ports
At least 2 USB 3,.0 ports
WAN+LAN port aggregation and failover
WAN+USB port aggregation and failover
Of course, much depends on the price point and target market for the next generation of Brume. When I previously worked in data center management with Cisco networking, perhaps the most critical criteria are actually that “edge” devices be secure and reliable 24x365 … they are devices that you just “set it and leave it” to just run.
GL-MV1000W has very poor WiFi performance and it causes a lot of problems. For the next generation of Brume, users can still use USB WiFi adapter to have wireless connections. Without built-in WiFi, the product can be much smaller but with much better computing speed. That’s the purpose of making this product.
I didn’t vote for this, but I would assume different colors for customized tasks, make it blink when someone accesses the panel/ssh, or set the color depending to which VPN you are connected (for example blue for nordvpn, red for expressvpn).
That’s just my thinking though, not sure what else I’d use it for🤷♂️
