Yes it is active, and everything is working ok otherwise.
And your main Internet page shows your pathway as active and the bottom of the screen shows: Using as WAN, Change to LAN?
Just disabled Adguard for fun, and ping started working…
… And software updates as well.
Thanks for your help! First time working with Adguard. Should it work with it still on?
Update lists working now?
Yes, it is working now. Should it work with Adguard on?
I have Adguard enabled (top button) but not the second option on that page, “AdGuard Home Handle Client Requests”, and mine is working.
Good job on finding what was blocking your connectivity!
Thanks again for your help - I really appreciate it!
I fully understand hitting a wall like that. Just need someone to walk through the issue with is all.
Feel free to mark the ‘Solution’ to let others know should they stumble across the same problem.
