I started upgrading packages with the following command:
opkg list-upgradable | cut -f 1 -d ' ' | xargs opkg upgrade
but it aborted due to insufficient disk space.
Collected errors:
* pkg_get_installed_files: Failed to open //usr/lib/opkg/info/luci-i18n-base-zh-cn.list: No such file or directory.
* wfopen: //usr/lib/opkg/info/curl.control: No space left on device.
* wfopen: //usr/lib/opkg/info/curl.postinst: No space left on device.
* wfopen: //usr/lib/opkg/info/curl.prerm: No space left on device.
* wfopen: /usr/bin/curl: No space left on device.
* pkg_write_filelist: Failed to open //usr/lib/opkg/info/curl.list: No space left on device.
* opkg_install_pkg: Failed to extract data files for curl. Package debris may remain!
* opkg_install_cmd: Cannot install package curl.
* opkg_conf_write_status_files: Can't open status file //usr/lib/opkg/status: No space left on device.
how do I fix this?
thanks.
