Happi
My Spitz X3000 prompted me to upgrade to v4.08, which I did.
- there used to be an option to stop GL calling home and checking for updates, now missing.
- the lock tower options are missing (it just shows modem AT commands)
- sending SMS doesn't work and the country code 44 for the UK is under GG (took me forever to find it).
Happi
2
Appears fixed after a reboot
Do you mean your router prompted you to update to 4.8.4?
Interesting you were prompted to update since its still listed only as a snapshot on their website. Mine is still sitting on 4.8.3
Happi
4
Yes, it prompted me, not sure of the version but this is what I’ve got now (looks the same as what you have).:
Yeah okay that is 4.8.3 which is the latest stable release. That makes sense
system
Closed
6
