Orange Color issue with GL-RM1PE KVM
I’m using the Comet PoE KVM (GL-RM1PE firmware v1.7.1 release 1) and I have a strange color issue.
There is something like an orange filter on the image returned through the KVM. Night mode is disabled on both the connecting machine and the target machine (both running Windows 11).
I looked in the color profile but didn't see anything problematic.
Is this a potential bug? I reset the KVM, but that didn't change anything.
Here is a screenshot where the problem is clearly visible, since the Google background is normally white.
Thank you!
Looks to me to a cable issue.
First:
Is the cable properly connected on both ends?, please fully reinsert them.
Second:
tried a different hdmi cable?
Often this yellowish hue means the connection isn't properly.
Could you please provide the graphics card driver information for your controlled device?
I've encountered this issue as well. Usually, restarting the controlled device or re-plugging the HDMI cable seems to fix it. I haven't seen it persist continuously.
I have seen this also on tv boxes with hdmi sometimes, to me it often happens if the cable got loosen by moving the device, the smallest interference could create this hue, idd replugging helps.
I saw also another post by a other staff Kyrie I believe, he suggested dark mode, I think he has a fair point, the OP only checked the color options but not dark mode, windows 11 has also styling options which simulate dark mode which can do odd things on screens.
I am also seeing heavy orange cast on my comet view. I think the reason -at least for me- is the Windows’ ‘Night Light’ feature. It shows orange cast when the Night Light turns on.
After restarting the remote machine, I no longer encounter any difficulties. I think it was related to night mode, which had trouble deactivating due to repeated attempts to connect/disconnect HDMI coupled with the use of remote desktop (mstsc). Likely a Windows bug…
Thank you for your help, happy holidays.
