Where can I find Original Firmware for GLinet AR150? I have updated to goldenorb and regretted only to know if I choose “advanced configuration”, it will have the exact same option as goldenorb firmware right?
I tried holding reset button and do just exactly the same steps. I even changed ip address to 192.168.1.2. When I typed 192.168.1.1 into firefox, why my connection timed out?
The difference is red light blink 10 times not 5 times before it stopped blinking while I hold reset button after I plug in lan cable first.
Update: By letting the red light blink 5 times, then when turned off, let go the reset button immediately can make the router accessible.
Dont wait 10 times blinking until turned off completely because it will make the router inaccessible.
