Is it possible to use Outline VPN client files with GL-inet routers? That is, have Outline running on a cloud server and have the router connect to the server as a client?
Outline is based on Shadowsocks and has some backing by Google.
For background information on the project, see:
Outline VPN is a free and open-source tool that deploys Shadowsocks servers on multiple cloud service providers. The software suite also includes client software for multiple platforms. Outline was developed by Jigsaw, a technology incubator created by Google.
The Outline Server supports self-hosting, as well as cloud service providers including DigitalOcean, Rackspace, Google Cloud Platform, and Amazon EC2. Installation involves running a command on its command-line interface, or in the case of...
This Reddit post hints that it may be unlikely to get Outline to work with a router:
Sorry, GL.iNet routers don’t support running Shadowsocks.
Just install luci-app-shadowsocks-libev, go to the advanced interface (luci) and paste your outline access key.
yuxin.zou:
Shadowsocks
@agnelli I doubt it given:
Shadowsocks is a free and open-source encryption protocol project, widely used in China to circumvent Internet censorship. It was created in 2012 by a Chinese programmer named "clowwindy", and multiple implementations of the protocol have been made available since. Shadowsocks provides an encrypted equivalent of a SOCKS proxy. A Shadowsocks client converts the Shadowsocks connection to SOCKS5 for local use. Unlike an SSH tunnel, Shadowsocks can also proxy User Datagram Protocol (UDP) tra On 22 ...
Dear all,
We regret to make the following annoucement. Due to current legal and policy restrictions in mainland China, we are unable to provide VPN and AdGuard Home features in our CN version products sold in mainland China. We understand that this may cause inconvenience, but we have to comply with local regulations. If you purchase GL.iNet devices from tmall.com or taobao.com , your devices will be CN version.
We have added this information to our product pages on TMall , our official store in…
@mahdif62 has the right idea but don't forget to make a backup beforehand in case things go wrong:
Keywords: backup, opkg, plugins, list, howto, script, shell, luci, restore, ipk, tarball, conf
Description
List user's (your) installed packages, writing them to a text file that can be used to reinstall the binaries of what a user manually installed. The resulting .list file will be use to opkg install to pull from the feeds. That is done with two commands in one execution.
The GL GUI doesn’t feature a backup function. Creating & restoring a backup achieve (.tar.gz, aka tarball) of all your …
