New owner of GL iNet router here, and tbh a bit of a tech biff. I bought the router to connect to my DS713+ in UK, from my house in Belgium. When i try loading the OVPN file that works just fine on my laptop, it comes up failed every time, below is the config file, any help appreciated;
dev tun
tls-client
remote *MY NAS ADDRESS* 1723
# The "float" tells OpenVPN to accept authenticated packets from any address,
# not only the address which was specified in the --remote option.
# This is useful when you are connecting to a peer which holds a dynamic address
# such as a dial-in user or DHCP client.
# (Please refer to the manual of OpenVPN for more information.)
float
# If redirect-gateway is enabled, the client will redirect it's
# default network gateway through the VPN.
# It means the VPN connection will firstly connect to the VPN Server
# and then to the internet.
redirect-gateway def1
# dhcp-option DNS: To set primary domain name server address.
# Repeat this option to set secondary DNS server addresses.
#dhcp-option DNS DNS_IP_ADDRESS
pull
# If you want to connect by Server's IPv6 address, you should use
# "proto udp6" in UDP mode or "proto tcp6-client" in TCP mode
proto tcp-client
script-security 2
comp-lzo
reneg-sec 0
cipher AES-256-CBC
auth SHA512
auth-user-pass
<ca>
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
</ca>
