OWE silently broken on Flint3
Device: GL-BE9300 (Flint3)
Firmware: 4.8.4 (OpenWrt 23.05-SNAPSHOT)
Setting encryption='owe' on a wifi-iface produces an open network with wpa=0 in the generated hostapd config. The network appears to work but has no encryption.
The issue is in /lib/wifi/hostapd.sh. The fix_iface function handles sae, sae-mixed, psk-mixed, and psk2, but has no case for owe. The encryption='owe' value passes through unrecognized and the script falls through to generating an open network config.
Upstream OpenWrt's hostapd.sh handles encryption='owe' as a first-class option. It sets wpa=2, wpa_key_mgmt=OWE, ieee80211w=2, and rsn_pairwise=CCMP automatically. The fork is missing this.
Workaround:
Instead of encryption='owe', use:
uci set wireless..encryption='ccmp'
uci set wireless..owe='1'
uci commit wireless
wifi
This uses the existing owe boolean flag that the script already supports (line 330 / line 980 in hostapd.sh) and correctly generates a hostapd config with wpa=2, wpa_key_mgmt=OWE, and ieee80211w=2.
Proper fix:
Add an owe) case to the fix_iface function in /lib/wifi/hostapd.sh, similar to how sae is handled:
owe)
    config_set "$section" encryption "ccmp"
    owe "1";;
Or sync the encryption handling with upstream OpenWrt which has full native OWE support.
Thank you for your report.
We’ll check with our development team to see if this can be addressed in a future release.
