Packet Loss while using my Wireguard Server
So I'm able to get my Wireguard Server set up, but I'm experiencing 25% packet loss whenever I connect a client router with the Server's Wireguard VPN.
I know it's the VPN issue because if I turn the VPN off and allow non-VPN traffic, I get 0% packet loss.
So I wonder, what could be the issues? Here's some details about my setup of my VPN Server Router:
  1. also broadcasting a WIFI network of its own
  2. it was in the corner of my living room which isn't a good location - I moved it near a window but it's still by a recessed balcony
I based those guesses^ on this thread but I'm unsure if it's talking about the same issue (the issue here is with my Server).
Do I need to buy an extender or just move my ServerRouter to a more exposed spot, or is there something in my ServerRouter settings that should be changed?
May I confirm that the server router, enable WG VPN server, and enable Wi-Fi, and the Wi-Fi wireless client will lose 25% packets. If the VPN server is disabled, there will be no packet loss (0%). Is that right?
If the client is wired connect to server router, and the VPN server is enabled, is there any packet loss?
It is not same as that issue. That is if enable repeater and not repeat any primary router, then the GL router Wi-Fi client will lose packets every 30 seconds. This is because when repeater is enabled and not connected, it will scan the surrounding WiFi every 30 seconds, and the scanning action will temporarily turn off itself Wi-Fi AP, thus the Wi-Fi connected device will drop.
Hi @bruce,
When I directly connect my ClientRouter to my ServerRouter via Ethernet (LAN port server, WAN port client), I still get packet loss
Try checking / adjusting your wireguard client(s) profile MTU settings.
You can also set a default MTU for the wireguard server
http://ROUTERIP/#/vpndashboard
Scroll to the bottom and fine wireguard server and select the options, there is the global MTU override box. The other way is to do a client by client adjustment via the "Wireguard Server > Profiles > Configs > (find device / config) > edit / cog icon > set more (from the "client configuration" popup, underneath the device name box) then from there you can set a MTU too.
Read situation 4
Server router and client router cannot be directly connected.
The principle of VPN is to build a tunnel in different networks so that they can access each other.
The server router and client router need to be placed in different networks.
For example, server router at home, client router in external networks such as hotel, Starbucks WiFi, phone hotspots, etc.
I tested for a few days with different MTUs... it did seem to get better but at the same time I also moved my server router closer to the window. But then again, there's still packet loss and it's the same amount regardless what MTU I use. I believe the improvement was from moving my router closer to the window
