Understood ax1800 uses ad guard for parental control. I can’t find info if ad guard allows blocking devices for certain period of time, like block device 1 12am-6am for example. Anyone can chip in? Thanks
You can currently do this in Luci, through the firewall:
Adjust the parameters according to your configuration.
Navigate to LuCI → Network → Firewall → Traffic Rules.
Click Add and specify:
Name:
Filter-Parental-Controls -
Protocol: Any
Source zone:
lan -
Destination zone:
wan -
Action: reject
- (Optional) If you want to add a MAC or IPlimitation, on the Advanced Settings tab specify:
Source MAC address:
00:11:22:33:44:55 -
Source IP address:
192.168.1.2
- On the Time Restrictions tab specify:
Week Days: Monday, Tuesday, Wednesday, Thursday, Friday
Start Time:
21:30:00 -
Stop Time:
07:00:00
- Click Save, then Save & Apply.
You can add another rule to apply time restrictions on weekend.
Source: [OpenWrt Wiki] Parental controls
Actually this can be done using openwrt’s built-in firewall.
I tried before and it works good. Only thing is that I have convert all time to UTC.
Thanks, can you immediately kill a device? Through time setting I’m guessing? Thanks
You set a time frame for the device to use Internet. When time is not in that frame, the device does not have Internet.
But to kill a device any time, just use the function in the default UI.
Ah there s an internet pause function in default ui? Thanks
Hello, has you test block Facebook.com , is possible?
