PC boot issues with KVM? Disable the Comet’s “Virtual Media” feature.
Thanks for the product — I have the Comet R1 and the PoE versions! It’s a Godsend for those that can’t RDP into their machines due to corporate policy!
I ran into a boot issue: my work PC wouldn’t start while the KVM was connected. Disabling the Comet’s “Virtual Media” storage feature fixed it. I suspect a boot/security conflict since keyboard/mouse and virtual storage share one USB connection or the PC just doesn’t like any media connected it at all (again, due to security).
If you see this, disable Virtual Media on the KVM. (I can’t change BIOS/USB boot settings — corporate locked PC.)
Thanks for taking the time to share this — it will definitely help other users in similar environments!
