Persistent Disconnection Issues with Modem_0001 on GL-X3000 using Movistar SIM
Hi GL.iNet Community,
I’m reaching out for assistance regarding a persistent issue I’ve been facing with my GL-X3000 router. I am using a Movistar SIM card, and while the router functions well under certain configurations, I continue to experience frequent disconnections on the interface modem_0001.
Issue Details:
  • Router Model: GL.iNet GL-X3000
  • Firmware Version: I have tried all available versions, but the only one that seems stable for me is 4.4.3.
  • SIM Provider: Movistar
  • Current Band Setting: 5G NSA Bands (This configuration has provided the most stable connection so far)
Log Excerpt:
Below is an excerpt from the log that shows the recurring problem with the modem_0001 interface:
Mon Jul 29 12:58:42 2024 daemon.notice netifd: Interface 'modem_0001_4' is now up
Mon Jul 29 12:58:42 2024 user.notice mwan3[24696]: Execute ifdown event on interface modem_0001_4 (unknown)
Mon Jul 29 12:58:43 2024 user.notice firewall: Reloading firewall due to ifdown of modem_0001_4 ()
Mon Jul 29 12:58:44 2024 user.notice mwan3[25145]: Execute ifup event on interface modem_0001_4 (rmnet_mhi0)
Mon Jul 29 12:58:44 2024 user.notice mwan3[25145]: Starting tracker on interface modem_0001_4 (rmnet_mhi0)
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:56:34:674] try to requestSetupDataCall 10 second later
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:56:44:678] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:56:44:679] call_end_reason is 1
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:56:44:679] call_end_reason_type is 2
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:56:44:679] call_end_reason_verbose is 210
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:56:44:679] try to requestSetupDataCall 20 second later
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:57:04:700] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:57:04:700] call_end_reason is 1
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:57:04:700] call_end_reason_type is 2
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:57:04:700] call_end_reason_verbose is 210
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:57:04:700] try to requestSetupDataCall 40 second later
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:57:44:744] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:57:44:745] call_end_reason is 1
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:57:44:745] call_end_reason_type is 2
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:57:44:745] call_end_reason_verbose is 210
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:57:44:745] try to requestSetupDataCall 60 second later
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:58:44:805] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Mon Jul 29 12:58:44 2024 daemon.notice netifd: modem_0001 (14045): [07-29_12:58:44:805] call_end_reason is 1
Observations:
  1. Firmware Versions: As mentioned, I have tested various firmware versions, but only version 4.4.3 works without issues.
  2. Band Configuration: Fixing the band to 5G NSA Bands seems to stabilize the connection, preventing frequent disconnections of modem_0001.
  3. Error Details: The logs repeatedly show errors with QMUXResult = 0x1, QMUXError = 0xe and call_end_reason is 1, indicating persistent problems in establishing a stable data call.
Request:
I’m looking for guidance on resolving these issues more permanently without being restricted to firmware 4.4.3. Is there a known issue with the newer firmware versions? Are there any additional settings I should try to stabilize the connection further?
Any help or suggestions would be greatly appreciated.
Thank you in advance!
This log does not affect
You turn on ipv6, it won't print this
When you say the line is broken, can you describe the phenomenon more clearly?
Is the signal lost?
Module disconnected?
  • Internet access is lost intermittently.
  • The modem_0001 interface goes down and comes back up frequently.
  • The connection is generally unstable, leading to disruptions in service.
Can you download the log when something goes wrong?
You can send it to me privately
or Can I see this phenomenon remotely?
Technical Support via GoodCloud.tar (192 KB)
Already did GoodCloud. How can I contact you privately?
I found that blocking mask to 5G NSA is making work the connection stable. Also in last firmware version.
This is the Log when not blocked:
Wed Jul 31 12:11:56 2024 daemon.err usbmuxd[11728]: [12:11:56.072][3] Initialization complete
Wed Jul 31 12:11:56 2024 daemon.err usbmuxd[11728]: [12:11:56.072][3] Enabled exit on SIGUSR1 if no devices are attached. Start a new instance with "--exit" to trigger.
Wed Jul 31 12:11:56 2024 daemon.info dnsmasq-dhcp[5444]: DHCPREQUEST(br-lan) 192.168.8.238 8c:85:90:52:26:8d
Wed Jul 31 12:11:56 2024 daemon.info dnsmasq-dhcp[5444]: DHCPACK(br-lan) 192.168.8.238 8c:85:90:52:26:8d MBP-de-Bernat
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:11:23:759] requestGetSIMStatus SIMStatus: SIM_READY
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:11:23:763] requestGetProfile[1] ///0/IPV4V6
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:11:23:765] requestRegistrationState2 MCC: 214, MNC: 1, PS: Detached, DataCap: UNKNOW
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:11:23:769] requestRegistrationState2 MCC: 214, MNC: 1, PS: Detached, DataCap: UNKNOW
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:11:23:771] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:11:24:560] requestRegistrationState2 MCC: 214, MNC: 1, PS: Attached, DataCap: LTE
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:11:24:612] requestSetupDataCall WdsConnectionIPv4Handle: 0xedc6cfc0
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:11:24:618] requestRegistrationState2 MCC: 214, MNC: 1, PS: Attached, DataCap: LTE
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:11:24:621] requestRegistrationState2 MCC: 214, MNC: 1, PS: Attached, DataCap: LTE
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:11:59:690] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:11:59:732] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Wed Jul 31 12:12:00 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:12:00:120] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Wed Jul 31 12:12:01 2024 kern.notice kernel: [   52.918018] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(2), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]96:3b:c8:71:e0:4d
Wed Jul 31 12:12:01 2024 kern.debug kernel: [   52.930925] entrytb_aid_aquire(): found non-occupied aid:6, allocated from:4
Wed Jul 31 12:12:01 2024 kern.warn kernel: [   52.937985] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:96:3b:c8:71:e0:4d
Wed Jul 31 12:12:01 2024 kern.notice kernel: [   52.948157] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - 96:3b:c8:71:e0:4d
Wed Jul 31 12:12:01 2024 kern.notice kernel: [   52.957531] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Jul 31 12:12:01 2024 kern.notice kernel: [   52.966630] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 2
Wed Jul 31 12:12:01 2024 kern.notice kernel: [   52.972897] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=2
Wed Jul 31 12:12:01 2024 kern.notice kernel: [   53.098064] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Wed Jul 31 12:12:01 2024 kern.notice kernel: [   53.104759] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Wed Jul 31 12:12:01 2024 kern.notice kernel: [   53.111542] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Wed Jul 31 12:12:01 2024 kern.notice kernel: [   53.118256] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Wed Jul 31 12:12:01 2024 kern.warn kernel: [   53.130085] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(rax0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=3 from 96:3b:c8:71:e0:4d
Wed Jul 31 12:12:01 2024 daemon.info dnsmasq-dhcp[5444]: DHCPREQUEST(br-lan) 192.168.8.129 96:3b:c8:71:e0:4d
Wed Jul 31 12:12:01 2024 daemon.info dnsmasq-dhcp[5444]: DHCPACK(br-lan) 192.168.8.129 96:3b:c8:71:e0:4d iPhone
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   54.831911] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]c4:35:d9:85:d3:f5
Wed Jul 31 12:12:03 2024 kern.debug kernel: [   54.844862] entrytb_aid_aquire(): found non-occupied aid:7, allocated from:4
Wed Jul 31 12:12:03 2024 kern.warn kernel: [   54.851944] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:c4:35:d9:85:d3:f5
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   54.862676] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - c4:35:d9:85:d3:f5
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   54.872226] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   54.881435] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   54.887546] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   54.907031] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - c4:35:d9:85:d3:f5
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   54.916646] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   54.925905] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   54.932231] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   55.010044] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   55.016705] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   55.023474] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Wed Jul 31 12:12:03 2024 kern.notice kernel: [   55.030207] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Wed Jul 31 12:12:03 2024 daemon.info dnsmasq-dhcp[5444]: DHCPREQUEST(br-lan) 192.168.8.205 c4:35:d9:85:d3:f5
Wed Jul 31 12:12:03 2024 daemon.info dnsmasq-dhcp[5444]: DHCPACK(br-lan) 192.168.8.205 c4:35:d9:85:d3:f5 Air-de-Maria
Wed Jul 31 12:12:03 2024 kern.warn kernel: [   55.043334] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=4 from c4:35:d9:85:d3:f5
Wed Jul 31 12:12:05 2024 daemon.info dnsmasq-dhcp[5444]: DHCPREQUEST(br-lan) 192.168.8.205 c4:35:d9:85:d3:f5
Wed Jul 31 12:12:05 2024 daemon.info dnsmasq-dhcp[5444]: DHCPACK(br-lan) 192.168.8.205 c4:35:d9:85:d3:f5 Air-de-Maria
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001_4 (10630): udhcpc: received SIGTERM
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001_4 (10630): udhcpc: unicasting a release of 100.78.65.165 to 100.78.65.166
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001_4 (10630): udhcpc: sending release
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001_4 (10630): udhcpc: entering released state
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001_4 (10630): Command failed: Permission denied
Wed Jul 31 12:12:08 2024 daemon.notice netifd: Interface 'modem_0001_4' is now down
Wed Jul 31 12:12:08 2024 daemon.notice netifd: Network alias '' link is down
Wed Jul 31 12:12:08 2024 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity loss
Wed Jul 31 12:12:08 2024 kern.info kernel: [   59.944134] net rmnet_mhi0: link_state 0x1 -> 0x0
Wed Jul 31 12:12:08 2024 daemon.notice netifd: Interface 'modem_0001_4' is disabled
Wed Jul 31 12:12:08 2024 daemon.notice netifd: Network device 'rmnet_mhi0' link is down
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:12:00:122] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:12:00:308] requestRegistrationState2 MCC: 214, MNC: 3, PS: Detached, DataCap: UNKNOW
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:12:00:312] requestRegistrationState2 MCC: 214, MNC: 3, PS: Detached, DataCap: UNKNOW
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:12:00:315] requestRegistrationState2 MCC: 214, MNC: 3, PS: Detached, DataCap: UNKNOW
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:12:08:179] requestRegistrationState2 MCC: 214, MNC: 3, PS: Detached, DataCap: UNKNOW
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:12:08:182] requestRegistrationState2 MCC: 214, MNC: 3, PS: Detached, DataCap: UNKNOW
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:12:08:186] requestRegistrationState2 MCC: 214, MNC: 3, PS: Detached, DataCap: UNKNOW
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:12:08:769] QmiWwanThread exit
Wed Jul 31 12:12:08 2024 daemon.notice netifd: modem_0001 (9885): [07-31_12:12:08:770] qmi_main exit
Wed Jul 31 12:12:08 2024 daemon.notice netifd: Interface 'modem_0001' is now down
Wed Jul 31 12:12:08 2024 user.notice mwan3[12436]: Execute ifdown event on interface modem_0001 (unknown)
Wed Jul 31 12:12:09 2024 user.info mwan3track[10590]: Detect ifdown event on interface modem_0001 (rmnet_mhi0)
Wed Jul 31 12:12:09 2024 user.notice mwan3track[10590]: Interface modem_0001 (rmnet_mhi0) is offline
Wed Jul 31 12:12:09 2024 kern.notice kernel: [   60.438297] 7981@C08L3,ap_peer_auth_req_at_idle_action() 717: AUTH - MBSS(0), Rcv AUTH seq#1, Alg=0, Status=0 from [wcid=1023]74:40:be:51:2d:e0
Wed Jul 31 12:12:09 2024 kern.debug kernel: [   60.451240] entrytb_aid_aquire(): found non-occupied aid:8, allocated from:4
Wed Jul 31 12:12:09 2024 kern.warn kernel: [   60.458333] 7981@C13L2,MacTableInsertEntry() 1537: New Sta:74:40:be:51:2d:e0
Wed Jul 31 12:12:09 2024 kern.notice kernel: [   60.476829] 7981@C08L3,ap_cmm_peer_assoc_req_action() 1647:  Recv Assoc from STA - 74:40:be:51:2d:e0
Wed Jul 31 12:12:09 2024 kern.notice kernel: [   60.486171] 7981@C08L3,ap_cmm_peer_assoc_req_action() 2170: ASSOC Send ASSOC response (Status=0)...
Wed Jul 31 12:12:09 2024 kern.notice kernel: [   60.495319] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Wed Jul 31 12:12:09 2024 kern.notice kernel: [   60.501645] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Wed Jul 31 12:12:09 2024 kern.notice kernel: [   60.626142] 7981@C15L3,WPABuildPairMsg1() 5280: <=== send Msg1 of 4-way
Wed Jul 31 12:12:09 2024 kern.notice kernel: [   60.632794] 7981@C15L3,PeerPairMsg2Action() 6202: ===>Receive msg 2
Wed Jul 31 12:12:09 2024 kern.notice kernel: [   60.639779] 7981@C15L3,WPABuildPairMsg3() 5557: <=== send Msg3 of 4-way
Wed Jul 31 12:12:09 2024 kern.notice kernel: [   60.646437] 7981@C15L3,PeerPairMsg4Action() 6632: ===>Receive msg 4
Wed Jul 31 12:12:09 2024 user.notice firewall: Reloading firewall due to ifdown of modem_0001 ()
Wed Jul 31 12:12:09 2024 kern.warn kernel: [   60.658101] 7981@C15L2,PeerPairMsg4Action() 6994: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=5 from 74:40:be:51:2d:e0
Wed Jul 31 12:12:09 2024 daemon.info dnsmasq-dhcp[5444]: DHCPREQUEST(br-lan) 192.168.8.130 74:40:be:51:2d:e0
Wed Jul 31 12:12:09 2024 daemon.info dnsmasq-dhcp[5444]: DHCPACK(br-lan) 192.168.8.130 74:40:be:51:2d:e0 LGwebOSTV
Wed Jul 31 12:12:18 2024 daemon.notice netifd: Interface 'modem_0001' is setting up now
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13402):
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13402): OK
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13402): ERROR
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13402): Failed to parse message data
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13402): Device only supports raw-ip mode but is missing this required driver attribute: /sys/class/net/rmnet_mhi0/qmi/raw_ip
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:694] QConnectManager_Linux_V1.6.3.1
Wed Jul 31 12:12:22 2024 daemon.notice netifd: Interface 'modem_0001' is now up
Wed Jul 31 12:12:22 2024 kern.err kernel: [   73.916678] [I][mhi_netdev_open] Opened net dev interface
Wed Jul 31 12:12:22 2024 daemon.notice netifd: Interface 'modem_0001_4' is enabled
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:696] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x801, bus=0x001, dev=0x004
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:696] network interface '' or qmidev '' is not exist
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:696] netcard driver = pcie_mhi, driver version = V1.3.4
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:696] qmap_mode = 1, qmap_version = 9, qmap_size = 15360, muxid = 0x81, qmap_netcard = rmnet_mhi0
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:696] Modem works in QMI mode
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:705] cdc_wdm_fd = 7
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:717] Get clientWDS = 14
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:720] Get clientWDS = 15
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:725] Get clientDMS = 1
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:728] Get clientNAS = 3
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:732] Get clientUIM = 2
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:735] Get clientWDA = 1
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:738] requestBaseBandVersion RM520NGLAAR01A07M4G
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:741] qmap_settings.rx_urb_size = 15360
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:742] qmap_settings.ul_data_aggregation_max_datagrams  = 11
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:742] qmap_settings.ul_data_aggregation_max_size       = 8192
Wed Jul 31 12:12:22 2024 daemon.notice netifd: modem_0001 (13959): [07-31_12:12:22:742] qmap_settings.dl_minimum_padding                 = 0
Wed Jul 31 12:12:23 2024 user.notice mwan3[13965]: Execute ifup event on interface modem_0001 (rmnet_mhi0)
Wed Jul 31 12:12:23 2024 user.notice mwan3[13965]: Starting tracker on interface modem_0001 (rmnet_mhi0)
Wed Jul 31 12:12:23 2024 user.notice mwan3track[10590]: Stopping mwan3track for interface "modem_0001"
Wed Jul 31 12:12:25 2024 user.info mwan3rtmon[8686]: Detect rtchange event.
Wed Jul 31 12:12:25 2024 kern.info kernel: [   77.106142] net rmnet_mhi0: link_state 0x0 -> 0x1
Wed Jul 31 12:12:25 2024 kern.info kernel: [   77.110932] IPv6: ADDRCONF(NETDEV_CHANGE): rmnet_mhi0: link becomes ready
Wed Jul 31 12:12:25 2024 daemon.notice netifd: Network device 'rmnet_mhi0' link is up
Wed Jul 31 12:12:25 2024 daemon.notice netifd: Network alias 'rmnet_mhi0' link is up
Wed Jul 31 12:12:25 2024 daemon.notice netifd: Interface 'modem_0001_4' has link connectivity
Wed Jul 31 12:12:25 2024 daemon.notice netifd: Interface 'modem_0001_4' is setting up now
Wed Jul 31 12:12:25 2024 daemon.notice netifd: modem_0001_4 (14687): udhcpc: started, v1.33.2
Wed Jul 31 12:12:26 2024 daemon.notice netifd: modem_0001_4 (14687): udhcpc: sending discover
Wed Jul 31 12:12:26 2024 daemon.notice netifd: modem_0001_4 (14687): udhcpc: sending select for 10.0.13.217
Wed Jul 31 12:12:26 2024 daemon.notice netifd: modem_0001_4 (14687): udhcpc: lease of 10.0.13.217 obtained, lease time 7200
Wed Jul 31 12:12:26 2024 daemon.notice netifd: Interface 'modem_0001_4' is now up
Wed Jul 31 12:12:26 2024 user.notice firewall: Reloading firewall due to ifup of modem_0001 (rmnet_mhi0)
Wed Jul 31 12:12:26 2024 user.notice mwan3[14914]: Execute ifup event on interface modem_0001_4 (rmnet_mhi0)
Wed Jul 31 12:12:26 2024 user.notice mwan3[14914]: Starting tracker on interface modem_0001_4 (rmnet_mhi0)
Wed Jul 31 12:12:29 2024 user.info mwan3rtmon[8686]: Detect rtchange event.
Wed Jul 31 12:12:29 2024 user.notice firewall: Reloading firewall due to ifup of modem_0001_4 (rmnet_mhi0)
I already sent you a private message
@bernicortes @ywp, came here with the same errors in my logs - different carrier.
Where you able to resolve this?
