Who would I have to bribe^H^H^H^H^H ask nicely to get a specific python package into the repo?
I’m looking for pexpect, so I can script the interaction with [other machines|the local modem] on my GL-MIFI. I tried pip-installing it, but I get Out Of memory. I guess the platform is not meant to compile itself.
So the only chance I have is to beg here, so $someone compiles it on much better hardware and provides it in the official repo.
Is this the way to do it, or is there a more success-probe way to tread?
thanks for pointing me in the right direction
simon
Out of memory while pip was compiling. Or better, while pip was preparing to compile, there was no output yet before it ran out of mem. I have a 2gig microSD in the Mifi, storage should not be a problem (though I don’t know whether pip knows yet how to use that part of the filesystem. But I don’t worry about that because memory is the issue at the moment).
is there a chance to get pexpect into the official repo?
Or does anyone have another easy way to script talking to the Mifi modem via python? (sending AT commands and expecting with timeout on its output) echo/cat will most likely NOT suffice.
thanks
simon
PS: I might have found a workable alternative, pyserial. BUT… that’s a python2 package in the repository. May I kindly ask you to also put that out as a python3 opkg?
