PIA Authentication-"get 3rd party provider token fail [20001211]
No connection using any PIA configuration connects. When I try to re-authenticate the credentials within the router, the “get 3rd party provider token fail [20001211]” errors appears.
I can login to the PIA website,and I can connect using the PIA VPN app, so I know my authentication and account access are working.
I thought this was related to 4.8.x, so I downgraded, but it still happens on 4.7.7.
Thanks for any help you can provide.
Please switch to manual DNS, such as 9.9.9.9, 8.8.8.8, etc., and try to update again.
