I need access from PC to PC2. I can ping from PC ( 192.168.8.100) to GL-MT300N-V2 ( 192 .168.100.1) and other devices connected to router-modem(83.133.3.85) …but I can’t ping to PC2…
Are there any way to access to LAN device’s ?
Is it necessary some interface? How can I do it?
While awaiting for other experts to chime in, perhaps you would like to explore the Site2Site feature using the GL.iNet GoodCloud. Most important is to set up the main node properly and the rest of the links, the GoodCloud will handle it. Also ensure your firmware is Ver3.102.
But I have same problem, using main node device, I can ping node 1 router, buy I cannot ping device connected to node 1 router.
Example:
-ping from 192.168.8.100(PC1) to 192.168.10.1(Node 1 router) successful.
-ping from 192.168.8.100(PC1) to 192.168.10.100 ( PC2) NOT successful.
I reseted firmware in both MT300 Router devices.
I am trying now with Wireguard VPN method. But It didn`t successfully.
I can ping between client and server Routers ( 192.168.8.100-192.168.120.1) and / 192.168.120.100-192.168.8.1). But i can´t ping between LAN devices directly.
I don’t know how to explain it in detail. but in my case that time. exactly can not ping even access to the router network. after I added the rule. it works well. good luck ^^
