Hi All,
I need to ping/reach my home PC from the work PC. The connecction architecture is as follow
I’d like to use wireguard. I tried with sample on
gl i.net webiste (GL-MT300N-V2 as Wireguard server and Work PC as Wireguard client) but I’m not able to ping the Home PC from work PC…
Every suggestion is kindly appreciated!
Thanks!
admon
January 6, 2024, 5:19pm
2
Windows?
Ping is usually disabled by the firewall. You should check this.
slesar
January 6, 2024, 6:24pm
3
Just a ping between work PC and home PC?
Why not try to use Goodcloud ? to check router is work, clients, etc.
not just ping, I need to 100% reach the PC (VNC, FTP,…) so I need a way to connect (VPN?) the home PC and Work PC
does the Goodcloud allow to connect the home and work PCs?
admon
January 6, 2024, 7:56pm
6
Disable the firewall on your PC for testing. If it works, create the necessary exclusions for the services you need.
No.
Wait, the work-router isn’t an GL inet one?
How do you think you can connect the devices if none of them are “in your hand”?
