Pixel 7 and SlateAX (4.0.1 and 4.1b3) - Pixel 7 Wifi will disconnect and reconnect in loop.
Pixel can connect fine to TPlink router and other networks (MT1300).
The SlateAX seems to be disconnecting the device over and over (every second)
some more info you can add:
encryption type (wpa3?)
are you using same antenna (5ghz) for wwan and ap and different encryption? (never has worked unless openwrt has changed)
I have seen wpa3 behave like this and the only solution was to connect by bssid insead of ssid
I have a similar problem when using 5ghz as WAN and AP (not using DFS channels).
I have a Xiaomi Poco F3 and everytime I connect it to 5ghz I have the following on log:
Sometimes the phone lose connection and then reconnects.
Two days ago I bought a Xiaomi 360 Home Security Camera 2k Pro and it completely refuse to connect to 5Ghz if using repeater. Nothing useful on log for the camera, in fact looking at the log it seems connected (normal pairwise key handshake completed and DHCPACK).
Hmm and 802.1w 802.11w is set to optional here right or disabled? (Both settings is fine aslong its not forced)
If its on, maybe try turn this off and see if it keeps connected, you see this in the luci wireless settings.
Theres maybe two things to might check:
The dhcp range being requested is correct and not over the range?
Another issue could be in the mixed wpa3/wpa2 sae cipher some devices still don’t like this for some odd reason, then wpa2 works.
Maybe theres also some relevant kernel log information for this unknown event, I did a quick google but couldn’t really find a reason for this than only stumping on a crash log for another device on the openwrt forums, technically everything could have happened there.
Edit:
I notice you use channel 149, it depends on your country but for example in my country the netherlands 5g can be a little dramatic, I readed somewhere we can only use the lowest segment of 5g or the radar detection kicks devices off, so I keep mine on the lowest band of 5G.
I have a Firewalla Blue+, it acts as a drop in gateway, where it spoofs the ARP.
With the Firewalla unplugged, my Pixel 7 seems to stay connected to the SlateAX.
