Please consider hiding hostname of device by default
Please consider hiding hostname of device by default.
I did a quick search in your forum and found that not only me having similar issues.
Here is where to find this:
You see, because of using MAC randomization on nearly all devices (Android and IPhone come with that enabled by default) many network filters in public wifi started to filter devices by hostname.
And if there is something looking like hostname that been put in their blacklist they drops connection completely.
Using Kali Lunux and doing some advanced research stuff I found out that many of routers blocked not only by MAC but by hostname too.
Here is example:
If you name your computer in our City Mall "MT3000" or "E750" you will end up without connection. An to fix this you will need to change BOTH MAC and hostname.
Mac change already built in firmware but hostname exposed.
And after multiple test, yes, simply hiding hostname WILL fix issue and allow router to work in Mall.
@alzhao please look into this
I think there should be a toggle to hide it.
Hiding it will also add benefit for privacy not only enhance connectivity.
Or maybe randomize it? But I think better just hide.
Let me check with team
When Repeater uses random MAC, not reporting hostname has been implemented in v4.6, please use v4.6 and above version to try again, thanks!
