OK, I start again.
My setup for the internal network is this:
ISP ↔ Flint2 WAN 2 ↔ Zyxel 1900 p1 ↔ Flint 1 (WAN)
I have the main SSID configured on both Flints and the Guest on Flint 2.
Also, I have:
- Unconfigured Lan 2 from the
br-lan
- Added a new Interface named
VOIP
, addedlan2
and configured Firewall just fine. I can access the ATA that is connected to this port without issue.
What I need now is to:
- Configure a new SSID for 2.4Ghz named IoT.
- Extend the 3 SSID (main, Guest, IoT) to the second Flint.
Since my last attempt to do so broke my network setup badly, I would like to follow a more detailed approach and I also need your help to understand a few things.
I start with the IOT SSID.
I want to add this configuration in /etc/config/network
vi /etc/config/network
config interface 'iot'
option force_link '1'
option type 'bridge'
option proto 'static'
option ipaddr '192.168.10.1'
option netmask '255.255.255.252'
option ip6assign '60'
option multicast_querier '1'
option igmp_snooping '1'
option isolate '0'
option bridge_empty '1'
option disabled '0'
and
vi /etc/config/wireless
config wifi-iface 'IoT'
option device 'radio0'
option network 'iot'
option mode 'ap'
option ifname 'wlan0-2'
option encryption 'sae-mixed'
option key 'ssid_password'
option ssid 'my_iot_ssid'
option disabled '0'
option wds '1'
option isolate '1'
option hidden '0'
which is an exact copy of the guest
interface.
Question 1:
How is it possible for this setup to work since there is no bridge configured? And this is the case for the Guest network too, since in luci
we see that the Guest Interface is associated with the br-guest
device but there is no definition of that bridge in the /etc/config/network
, or in any other file that I checked.
An alternative method seems to be this:
option isolate '0'
option disabled '0'
(I found this proposal here)
So, generally speaking I would like to understand how this is working.
