Hi, quick question, upon selecting plug-ins section it appears there is an update available for iperf3. will the router automatically update this and any others that show up in the future or do I have to action the update button? and then regularly check for updates in the future?
Suppose one could use cron task to automatically update.
I haven't seen a choice for auto update plug-in.
Maybe safer to do of manual task.
Example of a similar task. Might be edited to plugin.
https://querysity.com/openwrt-auto-update-cron/
Other web page openwrt I lost had example.
The problem is practical testing.
Generally manually updating the plug-in is safer and more secure.
Manual update means that after the user confirms and clearly understands what version to update from, leaving the user with the right to know.
The plug-in will not be automatically updated, and the firmware upgrading as well, they will need to be manually operated and confirmed by the user.
Thanks @bruce makes sense, I’m loving this router! I will keep an eye out for updates.
Many thanks again.
