The poe feature, this means I can power the router with a poe enabled ethernet cable?
Or does it mean the router can output 48v from it’s LAN ports? Meaning the router converts 5 Volts to 48 V.
It is
can power the router with a poe enabled ethernet cable 48V
Not
PoE output
ok thansk for clearing that up
