Hello all… New user to this product… Here is my issue
I have a GL-AR750S we have it in a device at a customer location. The GL device is connected and connected to the openvpn access server I have hosted on Google.
The issue seems to be the ports are not forwarding on the vpn. I can reach the web console, ping, and ssh of the gl device from my client on the vpn, but i am unable to access any device behind the gl device…
He is what i have tried simply using port forward from the firewall tab turn port forward on for a port say 84 going to internal 80 of device 192.168.140.10 no response but locally I get a web console from the inside of the gl device…
I went to advanced settings and set a port forward in the firewall section as well still same results…
Then i went to the firewall rules and added a rule that any from opvn to lan is allow, at the same time added a rule to allow all from lan to opvn still no results…
I do see traffic hitting the firewall under the connections tab in advanced settings - status- graphs- connections
I see my ip on the vpn hitting the port 84 but no response… So now I’m at a loss… My other products i have used Cisco, netgear, fortinet all work but this little device doesn’t seem to pass ports…
Any help would be fantastic…
Thanks
