I have a remote Flint device, it’s situated behind a WAN router.
Which ports do I need to forward through the WAN router for Goodcloud to reach the Flint?
Thank you
Thank you
I would say none since it’s some Websocket/RTC thing.
A little history here.
I have had this router working on on Goodcloud for a couple of years now.
I simply put the Flint on the Verizon routers DMZ
But I made a change yesterday and when I did the Flint dropped off Goodcloud ![]()
I disabled the remote access DDNS permissions, as follows
As far as I can understand, I do not see why this should cause the Flint to drop off Goodcloud.
So now I’m trying to recover it and I do not have a person who can do anything other than reboot it unfortunately. It’s at a non techy friends house.
Thanks
Well, DMZ is like opening ALL ports. Would not really recommend it.
If the Flint can’t connect to the cloud and you can’t connect to the Flint (not via VPN nor SSH) … there is no way to make it work again. The screen shows the DDNS, not the Goodcloud part.
Thanks admon, yeah the reason I shut down the DDNS remote access stuff yesterday is to make it a little more secure, being on the DMZ and all isn’t ideal.
Anyway, I did not change anything in the Goodcloud part, only the DDNS remote access part.
I can still Wireguard VPN to the Flint - that works fine.
It’s just Goodcloud that’s the problem.
So what exactly is the problem? Is the device offline in GoodCloud?
If yes, check the logs on the device itself.
The device is remote.
Because the device is offline in Goodcloud I cannot connect to it, for admin stuff.
I can however still Wireguard VPN to it.
I’m trying to figure out a way to get to it, and it’s already on the WAN router DMZ thus all open ports should be exposed.
If you can Wireguard to it, you can SSH into it as well.
So in that case logread | grep gl-cloud would help you troubleshooting.
If you can’t reach the admin interface nor SSH, there is no way to get it work again.
Yeah I can Wireguard to the Flint just fine but the SSH port 22 is not open.
It might just be that it’s clicked off in Goodcloud config.
But the point remains the same, why should Goodcloud go down for me just editing DDNS settings?
You see what I mean?
Thanks
Without reading the logs - which you can’t do right now - no one will be able to answer this question. It should not go down, maybe a bug, maybe a feature…
Yeah I agree. I might be able to get someone to drive remotely for me and gets logs to get to the bottom of this… keep you posted.
Thx
Am I right that you can’t even reach the Web GUI while connected by Wireguard?
Okay I managed to get into the router to get some logs, over the Wireguard connection ![]()
I don’t just want to reboot this Flint because I would like to understand why it dropped off Goodcloud for no good reason.
What do you guys think?
There are some errors in the NGNIX log error file.
2024/01/24 17:40:36 [error] 4223#0: *421 “/www/ubus/gl_home.html” is not found (2: No such file or directory), client: 192.168.8.1, server: , request: “POST /ubus/?1706136035540 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci”
2024/01/24 17:40:44 [error] 4225#0: *442 “/www/ubus/gl_home.html” is not found (2: No such file or directory), client: 192.168.8.1, server: , request: “POST /ubus/?1706136044005 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:46 [error] 4224#0: *465 open() “/www/luci-static/resources/protocol/wgserver.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/wgserver.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:46 [error] 4223#0: *466 open() “/www/luci-static/resources/protocol/qmi.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/qmi.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:46 [error] 4225#0: *469 open() “/www/luci-static/resources/protocol/wwan.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/wwan.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:46 [error] 4225#0: *468 open() “/www/luci-static/resources/protocol/wgclient.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/wgclient.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:46 [error] 4223#0: *471 open() “/www/luci-static/resources/protocol/ovpnclient.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/ovpnclient.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:46 [error] 4224#0: *472 open() “/www/luci-static/resources/protocol/qcm.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/qcm.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:46 [error] 4222#0: *473 open() “/www/luci-static/resources/protocol/callip.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/callip.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:47 [error] 4224#0: *477 open() “/www/luci-static/resources/protocol/directip.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/directip.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:47 [error] 4223#0: *478 open() “/www/luci-static/resources/protocol/3g.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/3g.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:47 [error] 4222#0: *479 open() “/www/luci-static/resources/protocol/wireguard.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/wireguard.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:47 [error] 4224#0: *481 open() “/www/luci-static/resources/protocol/ncm.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/ncm.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:47 [error] 4224#0: *480 open() “/www/luci-static/resources/protocol/ovpnserver.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/ovpnserver.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:40:47 [error] 4223#0: *484 open() “/www/luci-static/resources/protocol/relay.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/relay.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/”
2024/01/24 17:42:45 [error] 4222#0: *650 open() “/www/luci-static/resources/protocol/qmi.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/qmi.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:45 [error] 4224#0: *652 open() “/www/luci-static/resources/protocol/wgclient.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/wgclient.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:45 [error] 4223#0: *651 open() “/www/luci-static/resources/protocol/wgserver.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/wgserver.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:45 [error] 4223#0: *653 open() “/www/luci-static/resources/protocol/wwan.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/wwan.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:45 [error] 4223#0: *654 open() “/www/luci-static/resources/protocol/ovpnclient.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/ovpnclient.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:45 [error] 4225#0: *655 open() “/www/luci-static/resources/protocol/qcm.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/qcm.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:45 [error] 4223#0: *656 open() “/www/luci-static/resources/protocol/callip.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/callip.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:45 [error] 4224#0: *657 open() “/www/luci-static/resources/protocol/directip.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/directip.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:45 [error] 4222#0: *658 open() “/www/luci-static/resources/protocol/3g.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/3g.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:46 [error] 4225#0: *661 open() “/www/luci-static/resources/protocol/wireguard.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/wireguard.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:46 [error] 4223#0: *662 open() “/www/luci-static/resources/protocol/ovpnserver.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/ovpnserver.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:46 [error] 4224#0: *663 open() “/www/luci-static/resources/protocol/ncm.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/ncm.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
2024/01/24 17:42:46 [error] 4225#0: *664 open() “/www/luci-static/resources/protocol/relay.js” failed (2: No such file or directory), client: 192.168.8.1, server: , request: “GET /luci-static/resources/protocol/relay.js?v=git-21.284.67084-e4d24f0 HTTP/1.1”, host: “127.0.0.1”, referrer: “https://rtty-web-cloud-us.goodcloud.xyz/cgi-bin/luci/admin/network/dhcp”
cat: can’t open ‘/var/log/nginx/access.log’: No such file or directory
Wrong log, nginx log isn’t relevant.
Here’s the main log…
Fri Jan 26 12:05:53 2024 daemon.info dnsmasq[18733]: read /etc/hosts - 4 addresses
Fri Jan 26 12:05:53 2024 daemon.info dnsmasq[18733]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Fri Jan 26 12:05:53 2024 daemon.info dnsmasq-dhcp[18733]: read /etc/ethers - 0 addresses
Fri Jan 26 13:05:57 2024 daemon.info dnsmasq[18733]: read /etc/hosts - 4 addresses
Fri Jan 26 13:05:57 2024 daemon.info dnsmasq[18733]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Fri Jan 26 13:05:57 2024 daemon.info dnsmasq-dhcp[18733]: read /etc/ethers - 0 addresses
Fri Jan 26 14:06:00 2024 daemon.info dnsmasq[18733]: read /etc/hosts - 4 addresses
Fri Jan 26 14:06:00 2024 daemon.info dnsmasq[18733]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Fri Jan 26 14:06:00 2024 daemon.info dnsmasq-dhcp[18733]: read /etc/ethers - 0 addresses
Fri Jan 26 14:07:00 2024 cron.err crond[3694]: USER root pid 28852 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:07:00 2024 cron.err crond[3694]: USER root pid 28853 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:08:00 2024 cron.err crond[3694]: USER root pid 30313 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:10:00 2024 cron.err crond[3694]: USER root pid 651 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:11:00 2024 cron.err crond[3694]: USER root pid 2178 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:11:00 2024 cron.err crond[3694]: USER root pid 2179 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:12:00 2024 cron.err crond[3694]: USER root pid 3589 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:12:00 2024 cron.err crond[3694]: USER root pid 3590 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:13:00 2024 cron.err crond[3694]: USER root pid 5090 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:13:00 2024 cron.err crond[3694]: USER root pid 5091 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:14:00 2024 cron.err crond[3694]: USER root pid 6493 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:14:00 2024 cron.err crond[3694]: USER root pid 6494 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:15:00 2024 cron.err crond[3694]: USER root pid 7970 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:15:00 2024 cron.err crond[3694]: USER root pid 7971 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:16:00 2024 cron.err crond[3694]: USER root pid 9451 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:16:00 2024 cron.err crond[3694]: USER root pid 9452 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:17:00 2024 cron.err crond[3694]: USER root pid 10944 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:17:00 2024 cron.err crond[3694]: USER root pid 10945 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:17:51 2024 authpriv.notice sudo: root : PWD=/www/cgi-bin ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – stop
Fri Jan 26 14:17:52 2024 user.notice ddns-scripts[14544]: glddns: PID ‘14544’ terminated by ‘SIGTERM’ at 2024-01-26 14:17
Fri Jan 26 14:17:52 2024 authpriv.info dropbear[12347]: Child connection from 180.101.88.231:60335
Fri Jan 26 14:17:53 2024 authpriv.notice sudo: root : PWD=/www/cgi-bin ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – start
Fri Jan 26 14:17:53 2024 user.notice ddns-scripts[12388]: glddns: PID ‘12388’ started at 2024-01-26 14:17
Fri Jan 26 14:17:54 2024 authpriv.info dropbear[12347]: Exit before auth from <180.101.88.231:60335>: Disconnect received
Fri Jan 26 14:18:00 2024 cron.err crond[3694]: USER root pid 12795 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:18:00 2024 cron.err crond[3694]: USER root pid 12796 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:19:00 2024 cron.err crond[3694]: USER root pid 14295 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:19:00 2024 cron.err crond[3694]: USER root pid 14296 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:20:00 2024 cron.err crond[3694]: USER root pid 15672 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:20:00 2024 cron.err crond[3694]: USER root pid 15673 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:21:00 2024 cron.err crond[3694]: USER root pid 17169 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:21:00 2024 cron.err crond[3694]: USER root pid 17170 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:22:00 2024 cron.err crond[3694]: USER root pid 18576 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:22:00 2024 cron.err crond[3694]: USER root pid 18577 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:23:00 2024 cron.err crond[3694]: USER root pid 20075 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:23:00 2024 cron.err crond[3694]: USER root pid 20076 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:24:00 2024 cron.err crond[3694]: USER root pid 21489 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:24:00 2024 cron.err crond[3694]: USER root pid 21490 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:25:00 2024 cron.err crond[3694]: USER root pid 22958 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:25:00 2024 cron.err crond[3694]: USER root pid 22959 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:25:03 2024 daemon.notice netifd: wan (13101): udhcpc: sending renew to 192.168.1.1
Fri Jan 26 14:25:03 2024 daemon.notice netifd: wan (13101): udhcpc: lease of 192.168.1.159 obtained, lease time 86400
Fri Jan 26 14:26:00 2024 cron.err crond[3694]: USER root pid 24375 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:26:00 2024 cron.err crond[3694]: USER root pid 24376 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:27:00 2024 cron.err crond[3694]: USER root pid 25873 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:27:00 2024 cron.err crond[3694]: USER root pid 25874 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:28:00 2024 cron.err crond[3694]: USER root pid 27358 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:28:00 2024 cron.err crond[3694]: USER root pid 27359 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:29:00 2024 cron.err crond[3694]: USER root pid 28869 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:29:00 2024 cron.err crond[3694]: USER root pid 28870 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:30:00 2024 cron.err crond[3694]: USER root pid 30274 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:30:00 2024 cron.err crond[3694]: USER root pid 30275 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:31:00 2024 cron.err crond[3694]: USER root pid 31670 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:31:00 2024 cron.err crond[3694]: USER root pid 31671 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:32:00 2024 cron.err crond[3694]: USER root pid 723 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:32:00 2024 cron.err crond[3694]: USER root pid 724 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:33:00 2024 cron.err crond[3694]: USER root pid 2149 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:33:00 2024 cron.err crond[3694]: USER root pid 2150 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:34:00 2024 cron.err crond[3694]: USER root pid 3660 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:34:00 2024 cron.err crond[3694]: USER root pid 3661 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:35:00 2024 cron.err crond[3694]: USER root pid 5081 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:35:00 2024 cron.err crond[3694]: USER root pid 5082 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:36:00 2024 cron.err crond[3694]: USER root pid 6574 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:36:00 2024 cron.err crond[3694]: USER root pid 6575 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:37:00 2024 cron.err crond[3694]: USER root pid 7978 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:37:00 2024 cron.err crond[3694]: USER root pid 7979 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:38:00 2024 cron.err crond[3694]: USER root pid 9556 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:38:00 2024 cron.err crond[3694]: USER root pid 9557 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:39:00 2024 cron.err crond[3694]: USER root pid 10961 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:39:00 2024 cron.err crond[3694]: USER root pid 10962 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:39:51 2024 authpriv.info dropbear[12217]: Child connection from 185.36.81.42:33288
Fri Jan 26 14:39:52 2024 authpriv.info dropbear[12217]: Exit before auth from <185.36.81.42:33288>: Exited normally
Fri Jan 26 14:40:00 2024 cron.err crond[3694]: USER root pid 12469 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:40:00 2024 cron.err crond[3694]: USER root pid 12470 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:41:00 2024 cron.err crond[3694]: USER root pid 13847 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:41:00 2024 cron.err crond[3694]: USER root pid 13848 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:42:00 2024 cron.err crond[3694]: USER root pid 15345 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:42:00 2024 cron.err crond[3694]: USER root pid 15346 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:43:00 2024 cron.err crond[3694]: USER root pid 16750 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:43:00 2024 cron.err crond[3694]: USER root pid 16751 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:43:48 2024 daemon.notice netifd: Network device ‘eth0’ link is down
Fri Jan 26 14:43:48 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity loss
Fri Jan 26 14:43:48 2024 kern.info kernel: [8142871.402487] nss-dp 3a001000.dp1 eth0: PHY Link is down
Fri Jan 26 14:43:48 2024 daemon.notice netifd: wan (13101): udhcpc: received SIGTERM
Fri Jan 26 14:43:48 2024 daemon.notice netifd: wan (13101): udhcpc: unicasting a release of 192.168.1.159 to 192.168.1.1
Fri Jan 26 14:43:48 2024 daemon.notice netifd: wan (13101): udhcpc: sending release
Fri Jan 26 14:43:48 2024 daemon.notice netifd: wan (13101): udhcpc: entering released state
Fri Jan 26 14:43:48 2024 daemon.notice netifd: wan (13101): Command failed: Permission denied
Fri Jan 26 14:43:48 2024 daemon.notice netifd: Interface ‘wan’ is now down
Fri Jan 26 14:43:48 2024 daemon.info avahi-daemon[3876]: Withdrawing address record for 192.168.1.159 on eth0.
Fri Jan 26 14:43:48 2024 daemon.info avahi-daemon[3876]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.1.159.
Fri Jan 26 14:43:48 2024 daemon.info avahi-daemon[3876]: Interface eth0.IPv4 no longer relevant for mDNS.
Fri Jan 26 14:43:48 2024 daemon.info avahi-daemon[3876]: Interface eth0.IPv6 no longer relevant for mDNS.
Fri Jan 26 14:43:48 2024 daemon.info avahi-daemon[3876]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:f79d.
Fri Jan 26 14:43:48 2024 daemon.info avahi-daemon[3876]: Withdrawing address record for fe80::9683:c4ff:fe27:f79d on eth0.
Fri Jan 26 14:43:48 2024 daemon.notice netifd: Interface ‘wan’ is disabled
Fri Jan 26 14:43:48 2024 daemon.notice netifd: Interface ‘wan’ is enabled
Fri Jan 26 14:43:48 2024 kern.info kernel: [8142871.464782] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Fri Jan 26 14:43:49 2024 user.notice mwan3[17941]: Execute ifdown event on interface wan (unknown)
Fri Jan 26 14:43:49 2024 user.info mwan3track[14159]: Detect ifdown event on interface wan (eth0)
Fri Jan 26 14:43:49 2024 user.notice mwan3track[14159]: Interface wan (eth0) is offline
Fri Jan 26 14:43:49 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Fri Jan 26 14:43:49 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity
Fri Jan 26 14:43:49 2024 daemon.notice netifd: Interface ‘wan’ is setting up now
Fri Jan 26 14:43:49 2024 kern.info kernel: [8142872.402076] nss-dp 3a001000.dp1 eth0: PHY Link up speed: 1000
Fri Jan 26 14:43:49 2024 kern.info kernel: [8142872.402604] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Fri Jan 26 14:43:49 2024 daemon.notice netifd: wan (18269): udhcpc: started, v1.33.2
Fri Jan 26 14:43:49 2024 daemon.notice netifd: wan (18269): udhcpc: sending discover
Fri Jan 26 14:43:49 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Jan 26 14:43:50 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – stop
Fri Jan 26 14:43:51 2024 user.notice ddns-scripts[12388]: glddns: PID ‘12388’ terminated by ‘SIGTERM’ at 2024-01-26 14:43
Fri Jan 26 14:43:51 2024 daemon.info avahi-daemon[3876]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:f79d.
Fri Jan 26 14:43:51 2024 daemon.info avahi-daemon[3876]: New relevant interface eth0.IPv6 for mDNS.
Fri Jan 26 14:43:51 2024 daemon.info avahi-daemon[3876]: Registering new address record for fe80::9683:c4ff:fe27:f79d on eth0..
Fri Jan 26 14:43:52 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – start
Fri Jan 26 14:43:52 2024 user.notice ddns-scripts[18674]: glddns: PID ‘18674’ started at 2024-01-26 14:43
Fri Jan 26 14:43:53 2024 daemon.notice netifd: wan (18269): udhcpc: sending discover
Fri Jan 26 14:43:56 2024 daemon.notice netifd: wan (18269): udhcpc: sending discover
Fri Jan 26 14:43:58 2024 user.err ddns-scripts[18674]: glddns: BusyBox nslookup error: ‘1’
Fri Jan 26 14:44:00 2024 cron.err crond[3694]: USER root pid 19109 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:44:00 2024 cron.err crond[3694]: USER root pid 19111 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:44:03 2024 user.err ddns-scripts[18674]: glddns: BusyBox nslookup error: ‘1’
Fri Jan 26 14:44:08 2024 user.err ddns-scripts[18674]: glddns: cURL Error: ‘6’
Fri Jan 26 14:44:08 2024 user.warn ddns-scripts[18674]: glddns: Transfer failed - retry 1/0 in 60 seconds
Fri Jan 26 14:44:20 2024 daemon.notice netifd: Network device ‘eth0’ link is down
Fri Jan 26 14:44:20 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity loss
Fri Jan 26 14:44:20 2024 kern.info kernel: [8142903.401614] nss-dp 3a001000.dp1 eth0: PHY Link is down
Fri Jan 26 14:44:20 2024 daemon.notice netifd: wan (18269): udhcpc: received SIGTERM
Fri Jan 26 14:44:20 2024 daemon.notice netifd: wan (18269): udhcpc: entering released state
Fri Jan 26 14:44:20 2024 daemon.notice netifd: wan (18269): Command failed: Permission denied
Fri Jan 26 14:44:20 2024 daemon.notice netifd: Interface ‘wan’ is now down
Fri Jan 26 14:44:20 2024 daemon.info avahi-daemon[3876]: Interface eth0.IPv6 no longer relevant for mDNS.
Fri Jan 26 14:44:20 2024 daemon.info avahi-daemon[3876]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:f79d.
Fri Jan 26 14:44:20 2024 daemon.notice netifd: Interface ‘wan’ is disabled
Fri Jan 26 14:44:20 2024 daemon.notice netifd: Interface ‘wan’ is enabled
Fri Jan 26 14:44:20 2024 daemon.info avahi-daemon[3876]: Withdrawing address record for fe80::9683:c4ff:fe27:f79d on eth0.
Fri Jan 26 14:44:20 2024 kern.info kernel: [8142903.502543] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Fri Jan 26 14:44:21 2024 user.notice mwan3[19763]: Execute ifdown event on interface wan (unknown)
Fri Jan 26 14:44:21 2024 user.info mwan3track[14159]: Detect ifdown event on interface wan (eth0)
Fri Jan 26 14:44:21 2024 user.notice mwan3track[14159]: Interface wan (eth0) is offline
Fri Jan 26 14:44:21 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Fri Jan 26 14:44:21 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity
Fri Jan 26 14:44:21 2024 daemon.notice netifd: Interface ‘wan’ is setting up now
Fri Jan 26 14:44:21 2024 kern.info kernel: [8142904.401634] nss-dp 3a001000.dp1 eth0: PHY Link up speed: 1000
Fri Jan 26 14:44:21 2024 kern.info kernel: [8142904.402133] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Fri Jan 26 14:44:21 2024 daemon.notice netifd: wan (20002): udhcpc: started, v1.33.2
Fri Jan 26 14:44:21 2024 daemon.notice netifd: wan (20002): udhcpc: sending discover
Fri Jan 26 14:44:21 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Jan 26 14:44:22 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – stop
Fri Jan 26 14:44:23 2024 user.notice ddns-scripts[18674]: glddns: PID ‘18674’ terminated by ‘SIGTERM’ at 2024-01-26 14:44
Fri Jan 26 14:44:23 2024 daemon.info avahi-daemon[3876]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:f79d.
Fri Jan 26 14:44:23 2024 daemon.info avahi-daemon[3876]: New relevant interface eth0.IPv6 for mDNS.
Fri Jan 26 14:44:23 2024 daemon.info avahi-daemon[3876]: Registering new address record for fe80::9683:c4ff:fe27:f79d on eth0..
Fri Jan 26 14:44:24 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – start
Fri Jan 26 14:44:24 2024 user.notice ddns-scripts[20406]: glddns: PID ‘20406’ started at 2024-01-26 14:44
Fri Jan 26 14:44:25 2024 daemon.notice netifd: wan (20002): udhcpc: sending discover
Fri Jan 26 14:44:28 2024 daemon.notice netifd: wan (20002): udhcpc: sending discover
Fri Jan 26 14:44:30 2024 user.err ddns-scripts[20406]: glddns: BusyBox nslookup error: ‘1’
Fri Jan 26 14:44:35 2024 user.err ddns-scripts[20406]: glddns: BusyBox nslookup error: ‘1’
Fri Jan 26 14:44:40 2024 user.err ddns-scripts[20406]: glddns: cURL Error: ‘6’
Fri Jan 26 14:44:40 2024 user.warn ddns-scripts[20406]: glddns: Transfer failed - retry 1/0 in 60 seconds
Fri Jan 26 14:45:00 2024 cron.err crond[3694]: USER root pid 21585 cmd . /lib/functions/modem.sh;check_ip
Fri Jan 26 14:45:00 2024 cron.err crond[3694]: USER root pid 21586 cmd sleep 30;. /lib/functions/modem.sh;check_ip
Fri Jan 26 14:45:12 2024 daemon.notice netifd: Network device ‘eth0’ link is down
Fri Jan 26 14:45:12 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity loss
Fri Jan 26 14:45:12 2024 kern.info kernel: [8142955.400940] nss-dp 3a001000.dp1 eth0: PHY Link is down
Fri Jan 26 14:45:12 2024 daemon.notice netifd: wan (20002): udhcpc: received SIGTERM
Fri Jan 26 14:45:12 2024 daemon.notice netifd: wan (20002): udhcpc: entering released state
Fri Jan 26 14:45:12 2024 daemon.notice netifd: wan (20002): Command failed: Permission denied
Fri Jan 26 14:45:12 2024 daemon.notice netifd: Interface ‘wan’ is now down
Fri Jan 26 14:45:12 2024 daemon.info avahi-daemon[3876]: Interface eth0.IPv6 no longer relevant for mDNS.
Fri Jan 26 14:45:12 2024 daemon.info avahi-daemon[3876]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:f79d.
Fri Jan 26 14:45:12 2024 daemon.info avahi-daemon[3876]: Withdrawing address record for fe80::9683:c4ff:fe27:f79d on eth0.
Fri Jan 26 14:45:12 2024 daemon.notice netifd: Interface ‘wan’ is disabled
Fri Jan 26 14:45:12 2024 daemon.notice netifd: Interface ‘wan’ is enabled
Fri Jan 26 14:45:12 2024 kern.info kernel: [8142955.502841] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Fri Jan 26 14:45:13 2024 user.notice mwan3[21986]: Execute ifdown event on interface wan (unknown)
Fri Jan 26 14:45:13 2024 user.info mwan3track[14159]: Detect ifdown event on interface wan (eth0)
Fri Jan 26 14:45:13 2024 user.notice mwan3track[14159]: Interface wan (eth0) is offline
Fri Jan 26 14:45:13 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Fri Jan 26 14:45:13 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity
Fri Jan 26 14:45:13 2024 daemon.notice netifd: Interface ‘wan’ is setting up now
Fri Jan 26 14:45:13 2024 kern.info kernel: [8142956.401234] nss-dp 3a001000.dp1 eth0: PHY Link up speed: 1000
Fri Jan 26 14:45:13 2024 kern.info kernel: [8142956.401433] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Fri Jan 26 14:45:13 2024 daemon.notice netifd: wan (22220): udhcpc: started, v1.33.2
Fri Jan 26 14:45:13 2024 daemon.notice netifd: wan (22220): udhcpc: sending discover
Fri Jan 26 14:45:14 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Jan 26 14:45:14 2024 daemon.info avahi-daemon[3876]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:f79d.
Fri Jan 26 14:45:14 2024 daemon.info avahi-daemon[3876]: New relevant interface eth0.IPv6 for mDNS.
Fri Jan 26 14:45:14 2024 daemon.info avahi-daemon[3876]: Registering new address record for fe80::9683:c4ff:fe27:f79d on eth0..
Fri Jan 26 14:45:15 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – stop
Fri Jan 26 14:45:15 2024 user.notice ddns-scripts[20406]: glddns: PID ‘20406’ terminated by ‘SIGTERM’ at 2024-01-26 14:45
Fri Jan 26 14:45:15 2024 daemon.notice netifd: Network device ‘eth0’ link is down
Fri Jan 26 14:45:15 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity loss
Fri Jan 26 14:45:15 2024 kern.info kernel: [8142958.401293] nss-dp 3a001000.dp1 eth0: PHY Link is down
Fri Jan 26 14:45:15 2024 daemon.notice netifd: wan (22220): udhcpc: received SIGTERM
Fri Jan 26 14:45:15 2024 daemon.notice netifd: wan (22220): udhcpc: entering released state
Fri Jan 26 14:45:15 2024 daemon.notice netifd: wan (22220): Command failed: Permission denied
Fri Jan 26 14:45:15 2024 daemon.notice netifd: Interface ‘wan’ is now down
Fri Jan 26 14:45:15 2024 daemon.info avahi-daemon[3876]: Interface eth0.IPv6 no longer relevant for mDNS.
Fri Jan 26 14:45:15 2024 daemon.info avahi-daemon[3876]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:f79d.
Fri Jan 26 14:45:15 2024 daemon.info avahi-daemon[3876]: Withdrawing address record for fe80::9683:c4ff:fe27:f79d on eth0.
Fri Jan 26 14:45:15 2024 daemon.notice netifd: Interface ‘wan’ is disabled
Fri Jan 26 14:45:15 2024 daemon.notice netifd: Interface ‘wan’ is enabled
Fri Jan 26 14:45:15 2024 kern.info kernel: [8142958.481322] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Fri Jan 26 14:45:16 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – start
Fri Jan 26 14:45:16 2024 user.notice ddns-scripts[22722]: glddns: PID ‘22722’ started at 2024-01-26 14:45
Fri Jan 26 14:45:22 2024 user.err ddns-scripts[22722]: glddns: BusyBox nslookup error: ‘1’
Fri Jan 26 14:45:23 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Fri Jan 26 14:45:23 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity
Fri Jan 26 14:45:23 2024 daemon.notice netifd: Interface ‘wan’ is setting up now
Fri Jan 26 14:45:23 2024 kern.info kernel: [8142966.401219] nss-dp 3a001000.dp1 eth0: PHY Link up speed: 1000
Fri Jan 26 14:45:23 2024 kern.info kernel: [8142966.401267] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Fri Jan 26 14:45:23 2024 daemon.notice netifd: wan (23291): udhcpc: started, v1.33.2
Fri Jan 26 14:45:23 2024 daemon.notice netifd: wan (23291): udhcpc: sending discover
Fri Jan 26 14:45:25 2024 daemon.info avahi-daemon[3876]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:f79d.
Fri Jan 26 14:45:25 2024 daemon.info avahi-daemon[3876]: New relevant interface eth0.IPv6 for mDNS.
Fri Jan 26 14:45:25 2024 daemon.info avahi-daemon[3876]: Registering new address record for fe80::9683:c4ff:fe27:f79d on eth0..
Fri Jan 26 14:45:27 2024 user.err ddns-scripts[22722]: glddns: BusyBox nslookup error: ‘1’
Fri Jan 26 14:45:27 2024 daemon.notice netifd: wan (23291): udhcpc: sending discover
Fri Jan 26 14:45:27 2024 daemon.notice netifd: wan (23291): udhcpc: sending select for 192.168.1.159
Fri Jan 26 14:45:27 2024 daemon.notice netifd: wan (23291): udhcpc: lease of 192.168.1.159 obtained, lease time 86400
Fri Jan 26 14:45:27 2024 daemon.info avahi-daemon[3876]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.159.
Fri Jan 26 14:45:27 2024 daemon.info avahi-daemon[3876]: New relevant interface eth0.IPv4 for mDNS.
Fri Jan 26 14:45:27 2024 daemon.info avahi-daemon[3876]: Registering new address record for 192.168.1.159 on eth0.IPv4.
Fri Jan 26 14:45:27 2024 daemon.notice netifd: Interface ‘wan’ is now up
Fri Jan 26 14:45:27 2024 user.notice mwan3[23404]: Execute ifup event on interface wan (eth0)
Fri Jan 26 14:45:28 2024 user.notice mwan3[23404]: Starting tracker on interface wan (eth0)
Fri Jan 26 14:45:28 2024 user.notice mwan3track[14159]: Stopping mwan3track for interface “wan”
Fri Jan 26 14:45:31 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Fri Jan 26 14:45:32 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – stop
Fri Jan 26 14:45:32 2024 user.notice ddns-scripts[22722]: glddns: PID ‘22722’ terminated by ‘SIGTERM’ at 2024-01-26 14:45
Fri Jan 26 14:45:33 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – start
Fri Jan 26 14:45:33 2024 user.notice ddns-scripts[24378]: glddns: PID ‘24378’ started at 2024-01-26 14:45
Fri Jan 26 14:45:41 2024 daemon.notice netifd: Network device ‘eth0’ link is down
Fri Jan 26 14:45:41 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity loss
Fri Jan 26 14:45:41 2024 kern.info kernel: [8142984.400941] nss-dp 3a001000.dp1 eth0: PHY Link is down
Fri Jan 26 14:45:41 2024 daemon.notice netifd: wan (23291): udhcpc: received SIGTERM
Fri Jan 26 14:45:41 2024 daemon.notice netifd: wan (23291): udhcpc: unicasting a release of 192.168.1.159 to 192.168.1.1
Fri Jan 26 14:45:41 2024 daemon.notice netifd: wan (23291): udhcpc: sending release
Fri Jan 26 14:45:41 2024 daemon.notice netifd: wan (23291): udhcpc: entering released state
Fri Jan 26 14:45:41 2024 daemon.notice netifd: wan (23291): Command failed: Permission denied
Fri Jan 26 14:45:41 2024 daemon.notice netifd: Interface ‘wan’ is now down
Fri Jan 26 14:45:41 2024 daemon.info avahi-daemon[3876]: Withdrawing address record for 192.168.1.159 on eth0.
Fri Jan 26 14:45:41 2024 daemon.info avahi-daemon[3876]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.1.159.
Fri Jan 26 14:45:41 2024 daemon.info avahi-daemon[3876]: Interface eth0.IPv4 no longer relevant for mDNS.
Fri Jan 26 14:45:41 2024 daemon.info avahi-daemon[3876]: Interface eth0.IPv6 no longer relevant for mDNS.
Fri Jan 26 14:45:41 2024 daemon.info avahi-daemon[3876]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:f79d.
Fri Jan 26 14:45:41 2024 daemon.info avahi-daemon[3876]: Withdrawing address record for fe80::9683:c4ff:fe27:f79d on eth0.
Fri Jan 26 14:45:41 2024 daemon.notice netifd: Interface ‘wan’ is disabled
Fri Jan 26 14:45:41 2024 daemon.notice netifd: Interface ‘wan’ is enabled
Fri Jan 26 14:45:41 2024 kern.info kernel: [8142984.460480] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Fri Jan 26 14:45:42 2024 user.notice mwan3[24886]: Execute ifdown event on interface wan (unknown)
Fri Jan 26 14:45:42 2024 user.info mwan3track[23855]: Detect ifdown event on interface wan (eth0)
Fri Jan 26 14:45:42 2024 user.notice mwan3track[23855]: Interface wan (eth0) is offline
Fri Jan 26 14:45:42 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Fri Jan 26 14:45:42 2024 daemon.notice netifd: Interface ‘wan’ has link connectivity
Fri Jan 26 14:45:42 2024 daemon.notice netifd: Interface ‘wan’ is setting up now
Fri Jan 26 14:45:42 2024 kern.info kernel: [8142985.400551] nss-dp 3a001000.dp1 eth0: PHY Link up speed: 1000
Fri Jan 26 14:45:42 2024 kern.info kernel: [8142985.401064] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Fri Jan 26 14:45:42 2024 daemon.notice netifd: wan (25138): udhcpc: started, v1.33.2
Fri Jan 26 14:45:42 2024 daemon.notice netifd: wan (25138): udhcpc: sending discover
Fri Jan 26 14:45:42 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Jan 26 14:45:44 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – stop
Fri Jan 26 14:45:44 2024 user.notice ddns-scripts[24378]: glddns: PID ‘24378’ terminated by ‘SIGTERM’ at 2024-01-26 14:45
Fri Jan 26 14:45:44 2024 daemon.info avahi-daemon[3876]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe27:f79d.
Fri Jan 26 14:45:44 2024 daemon.info avahi-daemon[3876]: New relevant interface eth0.IPv6 for mDNS.
Fri Jan 26 14:45:44 2024 daemon.info avahi-daemon[3876]: Registering new address record for fe80::9683:c4ff:fe27:f79d on eth0.*.
Fri Jan 26 14:45:45 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – start
Fri Jan 26 14:45:45 2024 daemon.notice netifd: wan (25138): udhcpc: sending discover
Fri Jan 26 14:45:45 2024 daemon.notice netifd: wan (25138): udhcpc: sending select for 192.168.1.159
Fri Jan 26 14:45:45 2024 user.notice ddns-scripts[25602]: glddns: PID ‘25602’ started at 2024-01-26 14:45
Fri Jan 26 14:45:45 2024 daemon.notice netifd: wan (25138): udhcpc: lease of 192.168.1.159 obtained, lease time 86400
Fri Jan 26 14:45:45 2024 daemon.info avahi-daemon[3876]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.159.
Fri Jan 26 14:45:45 2024 daemon.info avahi-daemon[3876]: New relevant interface eth0.IPv4 for mDNS.
Fri Jan 26 14:45:45 2024 daemon.info avahi-daemon[3876]: Registering new address record for 192.168.1.159 on eth0.IPv4.
Fri Jan 26 14:45:45 2024 daemon.notice netifd: Interface ‘wan’ is now up
Fri Jan 26 14:45:46 2024 user.notice mwan3[25690]: Execute ifup event on interface wan (eth0)
Fri Jan 26 14:45:46 2024 user.notice mwan3[25690]: Starting tracker on interface wan (eth0)
Fri Jan 26 14:45:46 2024 user.notice mwan3track[23855]: Stopping mwan3track for interface “wan”
Fri Jan 26 14:45:49 2024 user.notice firewall: Reloading firewall due to ifup of wan (eth0)
Fri Jan 26 14:45:50 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – stop
Fri Jan 26 14:45:50 2024 user.notice ddns-scripts[25602]: glddns: PID ‘25602’ terminated by ‘SIGTERM’ at 2024-01-26 14:45
Fri Jan 26 14:45:51 2024 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh – start
Fri Jan 26 14:45:52 2024 user.notice ddns-scripts[26641]: glddns: PID ‘26641’ started at 2024-01-26 14:45
Fri Jan 26 14:54:09 2024 authpriv.info dropbear[6519]: Child connection from 185.196.8.151:53648
Fri Jan 26 14:54:09 2024 authpriv.info dropbear[6519]: Exit before auth from <185.196.8.151:53648>: Exited normally
Fri Jan 26 14:54:20 2024 authpriv.info dropbear[6760]: Child connection from 185.196.8.151:44468
Fri Jan 26 14:54:21 2024 authpriv.warn dropbear[6760]: Login attempt for nonexistent user
Fri Jan 26 14:54:21 2024 authpriv.info dropbear[6760]: Exit before auth from <185.196.8.151:44468>: Disconnect received
Fri Jan 26 14:55:00 2024 cron.err crond[3694]: USER root pid 7767 cmd . /lib/functions/modem.sh;check_ip
I need to change the log level to get rid of those modem.sh crap filling the log.
Anyone from GL-INET Goodcloud here?
Can you tell why this router is “down” on Goodcloud?
Thanks
Please execute this command logread | grep gl-cloud
And I would say something is wrong with the internet connection itself:
Sounds like some DNS lookup error. Without knowing your network configuration I don’t know what it could be.
It returns nothing.
This Flint is directly connected to a Verizon home internet router, and I configured the Verizon router to put the Flint on the DMZ.
root@GL-AX1800:~# logread | grep gl-cloud
root@GL-AX1800:~#
Thanks for the help admon
Thx
/etc/init.d/gl-cloud status
and after that
/etc/init.d/gl-cloud restart
and then
