I just bought a GL-MT300N-V2 (upgraded to v3.102)
ISSUE: Port forwarding not happening in REPEATER mode.
This is the setup:
[ internet ]
[ ROUTER-MOVISTAR 192.168.1.1]
[192.168.1.77(static, wifi) GL-MT300N-V2 192.168.8.1]
(MT300 working in mode REPEATER, since
ROUTER-MOVISTAR is far and can not wire
them both together. Excellent signal though)
[192.168.8.66(static, ethernet) RASPBERRY ]
(MT300 and berry are ethernet wired)
This is the MT300 CONFIGURATION:
-Under the “Port forwards” section:
Name Int.IP Ext.Ports Int.Ports Protocol Status
ssh_pi 192.168.8.66 44100 22 TCP/UDP Enabled
-Under the “Open ports on router” section:
Name Port Protocol Status
ssh_for_pi 22 TCP/UDP Enabled
With all this said, when sitting from a wireless PC (192.168.8.179) and ssh to 192.168.8.66:22 works fine.
However, when from a wifi PC (192.168.1.102) i try to ssh to 192.168.1.77:44100 (hopping the MT300 will forward that to 192.168.8.66:22), it DOES NOT work.
Is there any chance to ssh access the raspberry from a pc outside the MT300 subnet?
Any help with this will be very appreciated!
Thanks!
