I’ve setup a new GL-B1300 with latest firmware (3.105) and I’ve connected the wan port to my VDSL2 modem running in bridge mode (with VLAN tagging on, as required by my ISP). Running the B1300 in router mode with PPPOE connection and everything works as expected - clients can connect to the internet both via ethernet and wireless.
The issue is port forwarding is not working. I’ve tried adding forwarding rules both in main UI and via Openwrt interface and none of them allow connections through to the host I’ve set (which has a reserved address under DHCP). This was working fine with my modem/router so I know the ports are open via my ISP and that the IP address for the internal host is correct (can access using IP address internally just fine).
I’ve checked that VPN is all OFF and I’ve not set any open ports or DMZ entries either.
Any ideas or settings I might have missed?
