Hello I have problems to use port forwarding, do not work. I have try different solution propose on forum but I’m still have problem.
the device works or router mode.
the wan is in DHCP mode IP
i have config on firewall menu Port forwarding and open the port on router but from WAN network I can views the web site on back lan ( forwarded from port forwarding)
… I can attach the image while I’m new user…
can you help me to find solution? I have try to open port 80 and show the login page on wan side. I think the problem is in iptables (port forwarding) , but the problem is so stupid… I also can’t find solution …
