I’ve two routers (gl-ax1800 and gl-sft1200). gl-ax1800 is the main router and gl-sft1200 is configured as repeater (connected via wifi to main router because it’s in different room). There is NAS behind gl-sft1200. I need to expose 8081 port in nas to be accessible from internet via port forwarding. Here is the setup
Internet ─► ISP MODEM ─► Router1(gl-ax1800, IP 192.168.8.1) ─► Router2(gl-sft1200, IP: 192.168.7.1, Repeater mode) ─► NAS(IP: 192.168.7.120)
Route2 is assigned an IP 192.168.8.157 by Router1
In Router1 (Firewalls > Port Forwards Menu):
I configured port forwarding as:
TCP/UDP | WAN |8081|192.168.8.157|8081
In Router2 (Firewalls > Port Forwards Menu):
TCP/UDP | WAN |8081|192.168.7.120|8081
When I try to access <MY_PUBLIC_IP>:8081, it’s geting timeout.
Could you please give me some advice where I misconfigured? Thanks in advance.
Are there any additional services installed manually on the AX1800?
Can I successfully access it over the Internet if I change to another External Port? e.g. TCP/UDP | WAN |34567|192.168.8.157|8081
I removed double nat and managed to connect router2 to router1 via extender. Now router2 (ip:192.168.8.157) doesn’t have dchp, NAS is getting IP (192.168.8.244) from router1. However, still port forwarding doesn’t work.
Here is traceroute
traceroute 192.168.8.244
traceroute to 192.168.8.244 (192.168.8.244), 64 hops max, 52 byte packets
1 gl-sft1200 (192.168.8.157) 11.008 ms 5.562 ms 5.590 ms
2 nas_home (192.168.8.244) 6.941 ms 4.472 ms 5.668 ms
My firewall config is following and doesn’t forward 8082 from wan to my nas port 8081 behind router2;
TCP/UDP | WAN ANY IP | 8082 | LAN 192.168.8.157|8082
TCP/UDP | LAN SRC IP 192.168.8.157 |8082| LAN 192.168.8.244 |8081
I also tried one port forwarding like following it didnt work as well.
TCP/UDP | WAN ANY IP | 8082 | LAN 192.168.8.244|8081
As a note, there are other machines behind router1 and port forwarding works for them.
One more note, port forwarding works to NAS when I put behind router1 without using router2
Somehow router2 drop packages. I appriciate any help
finally I solved the problem with following config.
router1:
port forwarding:
TCP/UDP | WAN ANY IP | 8081 | LAN 192.168.8.157|8081
router2:
connected to router1 as repeater
enable DMZ on NAS IP (which finally allows port forwarding from router1). still safe because router1 has firewall
Source ip on the second firewall should be any, or the ip of the first router, not the IP of the second router. Once you’ve got the second router on the same subnet, I’m not sure how it’s going to interpret WAN. I’d suggest explicitly naming 192.168.8.0/24 if you’re going that route.
Also, FWIW, I’d reconsider having your NAS be internet accessible without a VPN. Not really safe in 2023, even with a firewall on the rest of it (even if you were running an IDS/IPS, which you probably aren’t.
