I manually change the country to ‘JP’ to access the extended wifi channel list, In this way I can extend a wifi on channel 12. The problem is present only in the GUI when I select “Other” to manually type in the wifi ssid and channel nr. Even if the country is set to JP, the available list of possible channel is only up to 11. I think this list should change based on the selected country. Not sure if this is the right forum. Please advice and I’ll move the post.
Thanks
Roge
