Is it possible that the Flint becomes very slow in heat?
When I turn on the router in the morning, I have 80 mbps download. A few hours later it is only 10 mbps. If I tie the Flint in front of a fan and reboot, it’s back to 80 mbps.
Can anyone confirm this?
How can I open the case of the Flint to mount a fan?
I’d try increasing the airflow along the bottom before cracking open the case. Head over to your local dollar store. See if there’s a mesh spice/dish rack for cupboards in the kitchen section:
Failing that there’s always something like:
https://www.amazon.com/NewHail-Ultra-Quiet-3-Degree-Controller-Playstation/dp/B0BFZWV9FH/ref=sr_1_1?keywords=Quiet+USB+Fan+Dual-Ball+Bearings%2C+USB+Fan+5V&sr=8-1
I always have between 26 and 31 degrees room temperature. Would this be enough here or should I mount an active fan?
I have a Slate AX (GL-AXT1800) which features the same CPU/SOC as the Flint (Qualcomm IPQ6000 1.2GHz quad-core). It also has onboard fan/thermo control unlike the Flint. WG Client is active, Wi-Fi disabled, one LAN computer connected. Current ambient temp is 24°C/74°F. A floor/freestanding fan is on low circulating the room’s air. GL GUI → System → Overview shows the Slate AX is 64°C/147.2°F.
The fans have yet to kicked in (stock threshold is 75°C/167°F). It’s on a mesh spice rack. YMMV.
This sounds like a hardware driver issue with Ethernet of your machine NIC. Check you advance network settings against how they should be optimized.
