Is it possible to feed a solder pad inside the MIFI with 5v so a USB cable is not required for power?
I just realized there is an internal 5v header next to the battery connection, what is the connector type?
Bumping this, can someone provide a link to the connector type?
I think this adapter is called 2-Pin JST
Do you have a jst model?
This a a very common connector and you can buy it everywhere.
check here
FYI the connector is a JST XH 2.54mm connector, NOT a PH connector.
