Hey guys! I wanted to have a full on-the-go setup and was wondering if anyone used GL-AXT1800 with a powerbank and which one. 5V/4A seems as an odd combo for an inout. Cheers.
Used mine with a Anker Core+ 26800 model A1374. It will run on 5v/3a just don’t have any thing plugged into the USB.
I have this which does 22.5w out of the USB-A and 20W out of the USB-C. https://a.co/d/2jG9GTK. There’s also a 20,000 mah version as well.
When it comes to power banks with Power Delivery, the output watts varies with the output volts, which can go from 5 volts to 20+ volts. The higher watts may only be available at the higher volts.
GL.iNet routers do not support Power Delivery, so they will only draw 5 volts from the power bank that may result in lower watts. The specs and a label on the power bank should list the different output amps or watts at different output volts, which people should check to confirm the output for GL.iNet routers.
You are correct. I forgot to mention that the power bank I listed does 5v at the full wattage.
So we are in luck!
I also tried hooking up a USB hub with a portable 2.5” hdd, my phone, and a Slate 1 to it to draw as much power as I could while running an OpenVPN client, watching a movie on the MicroSD, and doing a Speedtest at the same time. I have it on Max transmission on both 2.5g & 5g, Ethernet connected, repeater as well. I could barely break 12 Watts on this thing. No sign of trouble from it either. How else can I get it to drain more power to test it?
You could try a 7200rpm or 10000rpm spinning HDD.
Challenge mode:
Does anybody know a power bank that will output 5V 3A and is powered by removable 18650 batteries??
