Hi, i’m trying to power this travel router via a USB-C PD charger, tried Apple’s Macbook pro over 90w, Anker etc with a USB-C to USB-C cable but cannot get the device to power up.
Can use a USB-A to USB-C cable and the plugged into an appropriate hotel USB-a port.
What am I doing wrong ? Seen people mention here you can use PD chargers. Wrong USB-C cable ?
Cable shouldn’t matter for such a low power and non-PD device. From my expierience, MacBook Pro USB-C ports support dumb devices as well, but I don’t know if they can supply 3A without risking breakage.
Unfortunately USB-C doesn’t solve charging issues – devices and chargers don’t have to use PD, there are many PD versions and PD doesn’t have to be fully implemented. Anyway, Beryl is a “dumb” device – it doesn’t support PD, so it doesn’t talk to the charger. Apple’s PD chargers expect a device to talk to it and say what voltage it wants. Otherwise charger won’ turn on. For Beryl, you need a charger that is “on” by default. You can see some charger tests on the following website.
